Pokud umíš anglicky, tak si můžeš přečíst názor Applu na nabíjení. Prostě je dobrý jet třeba půl hoďky na baterii, a pak to dobýt, aby se stav baterie pořád "měnil".For proper maintenance of a lithium-based battery, it?s important to keep the electrons in it moving occasionally. Apple does not recommend leaving your portable plugged in all the time. An ideal use would be a commuter who uses her notebook on the train, then plugs it in at the office to charge. This keeps the battery juices flowing. If on the other hand, you use a desktop computer at work, and save a notebook for infrequent travel, Apple recommends charging and discharging its battery at least once per month.
