Full backup iphone zatim len MAC
virus | čtv čer 12, 2008 2:55 am
jsem trohu googlil a nasel konecne fullbackup pro iphone
ted muzu skouset ruzne firmware
moje cestina neny dokonala ze jsem cizinec, tak ad nekdo to prelozi spravne navod do cestiny diky :wink: :lol:
Requirements
Mac OS/X 10.4 or later
BSD Subsystem installed on iPhone/iPod Touch (via Installer / System group). Version 2.0 or later can handle compatibility issues with other distributions.
OpenSSH installed on iPhone/iPod Touch (via Installer / System group)
rsa-key trust between your Mac and iPhone.
umi toho dost / vlastne to co neumi ITunes
the new utility for full backup of your Apple iPhone. Includes a set of different tools for reserve copying and restore the iPhone and iPod Touch through Wireless LAN. For work you will need BSD Subsystem and SSH.
Direct Download (M?c)
Famous iTunes from Apple can make only a copy of standard parameters of iPhone options and in a case of unforeseen circumstances, you can lose all your iPhone?s data. This cool utility will help to protect you from loss of your data, having store all your apps, emails, SMS messages, and different options e.t.c. through Wireless LAN.
Screenshots:
ilijusin | čtv čer 12, 2008 6:22 pm
Re: Full backup iphone zatim len MAC
presunul sem z navodu, jedna se vlastne o popis a zadny navod tam neni
a ted k tematu:
diky moc za info, rozhodne co nejdrive zkusim, aspon se uz nebudu tolik bat si hrat s iPhonkem :) jestli uz nekdo zkousel tak urcite co nejdriv hodte nejaky feedback
edit:
tak sem zkusil, a zatim se mi to nepovedlo
nepovede se mi Creating rsa keypairs mezi MACem a iPhonem, dneska uz nemam cas to resit ale o vikendu na to kouknu
virus | čtv čer 12, 2008 11:27 pm
me se to povedlo, musis (urcite vis) pockat na ssh nez generuje key
a pak to masti
fakt super
jsem skousel jak backup tak restore
ja mam PowerBook G4 s leopardem (10.5.3) a maka
sifis | pát čer 13, 2008 8:20 am
Jo jo funguje to :)
usakc | pát čer 13, 2008 6:14 pm
a to zazalohu je i baseband i taky
stř kvě 14, 2008 8:19 pm
Uživatelský avatar dalco | pát čer 13, 2008 9:49 pm
...a odkial ziskam z iPhone/MACka IP adresu? :?:
iPhone 16GB 2G 2.0.2 black, iPhone 16GB 3G white 2.2., iPhone 32GB 3GS black, iPhone4 32GB black, PowerBook 2GB RAM. 1,67 GHz PowerPC G4, MacBook Pro 4GB RAM 2.4 GHz Intel Core 2 Duo, MacOS X LEOš 10.7.1., iPod 3 gen. limited edition
sob kvě 03, 2008 6:05 am
Uživatelský avatar Rumsound | pát čer 13, 2008 10:04 pm
Nastaveni -> WiFi -> "nazev tve site a ta modra sipka vpravo" -> IP adresa
iPhone 4 16GB iOS 6.1 no JB
iPad2 16GB wifi iOS 6.1 no JB
ned kvě 04, 2008 4:59 pm
Uživatelský avatar dalco | sob čer 14, 2008 5:11 am
to Rumsound: Ďakujem 8)
Uživatelský avatar dalco | sob čer 14, 2008 5:31 am
...hmmm..Problem,,,
dostanem sa sem a terminal mi dalej nedovoli zadat password...robim niekde chybu?
##### Creating rsa keypairs
##### Please enter iPhone root password when requested!
##### Your MAC will ask if it should accept the device as 'trusted host'. Please enter 'yes' then.
<hit enter to proceed>
yes
##### Local RSA key already exists. Key will be used for iPhone.
The authenticity of host '192.168.1.2 (192.168.1.2)' can't be established.
RSA key fingerprint is ac:8a:02:eb:77:9d:e7:3b:73:d1:f2:ea:7d:40:c4:aa.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.1.2' (RSA) to the list of known hosts.
root@192.168.1.2's password:
za password: mam sedy obdlznik, ktory nereaguje na klavesnicu :?
virus | sob čer 14, 2008 1:10 pm
zceho vim heslo neuvidis a any **** len napis heslo --> alpine
a dej enter
Uživatelský avatar sergi | ned čer 15, 2008 5:57 pm
Tak jsem udělal BackUp.. proběhl úspěšně.. teď by mě jen zajímalo, kam se tu uložilo.. nemůžu to nikde najít.. jsem v záložce individual zadal cestu, ale backup jsem pak dělal standard, takže ta zvolena cesta asi není relevantní.. Nevíte, kde by to mohl uložit? V app support jsem to nenašel.. Když jsem dal show app packages, tak taky nic.. díky za odpověď
stř lis 07, 2007 3:21 pm
Uživatelský avatar caesar | ned čer 15, 2008 6:22 pm
Taky jsem to nemohl najit, ale ani jsem po tom nejak nepatral. Prepnul jem na individual, dal to na plochu a po backupu se tam objevil .zip s datem backupu
pon úno 11, 2008 5:37 pm
Uživatelský avatar emko1 | ned črc 27, 2008 1:40 pm
Vytvoření RSA proběhne v pořádku, vyzve mě k zavření okna terminálu a stisku OK.
Po stisku OK, znovu vyskočí okno s hlášením, že RSA není nakonigurováno, otevře se terminál a vše se opakuje pořád dokola..?
kde dělám chybu?
emko1
_/\_emko1_/\_
čtv dub 17, 2008 6:44 pm
filip.w | ned zář 14, 2008 7:27 pm
Mám stejný problem. Taky mě to vyzívá stále dokola ke kenfiguraci..... nevíte čim to může být?
iPhone 1G, 8Gb, 1.1.3, RiP
iPhone 3G, 8Gb, 3.0, Pwned, RiP
iPhone 4G, 16Gb, 4.1 RiP
iPhone 5S, 16Gb, 10 RiP
iPhone 7, 32Gb, 11.3.1
MacBook, 2,2GHz, 10.5. Leopard, RiP
MacBookPro 2,53Ghz, 10.6 Snow Leopard
ned kvě 11, 2008 2:46 pm
virus | pon zář 15, 2008 1:40 pm
heslo root ?!
musite take dat 2x heslo alpine (to vizaduje 2(jak si pomatuji)) a pak se ulozi
Uživatelský avatar emko1 | stř lis 05, 2008 3:57 pm
Už na to někdo přišel?
výpis trminálu:
The authenticity of host '10.0.0.128 (10.0.0.128)' can't be established.
RSA key fingerprint is 89:4e:9c:bb:67:f5:15:70:2a:69:75:f2:8a:2b:78:99.
Warning: Permanently added '10.0.0.128' (RSA) to the list of known hosts.
##### rsa configuration completed!
##### The following Applications list from your iPhone should show *without* asking for the password!
AppStore.app BossPrefs.app BossTool.app Calculator.app
Cycorder.app Cydia.app DemoApp.app FieldTest.app
Finder.app Flashlight.app Insomnia.app Installer.app
Maps.app MobileAddressBook.app MobileCal.app MobileMail.app
MobileMusicPlayer.app MobileNotes.app MobilePhone.app MobileSMS.app
MobileSafari.app MobileSlideShow.app MobileStore.app MobileTimer.app
MxTube.app Preferences.app Stocks.app SwirlyMMS.app
Weather.app Web.app YouTube.app
##### Close this window to return to iBackup
Zavřu okno terminálu, potvrdím OK a cca 20 vteřin se objeví hláška, že RSA není nakonfigurováno a opět se otevře terminál... a tak dokola
emko1
_/\_emko1_/\_
Uživatelský avatar Jirka Al | čtv lis 27, 2008 11:38 pm
Mě by zajímalo, co se stane, když zazálohuju všechno např. na FW 2.1 pak přejdu na 2.2 a pak budu chtít udělat obnovu. Daly by se takhle vrátit zpátky APP z Cydie včetně jejich nastavení a případných dat? Štve mě jak pokaždý o vše přijdu.
iPhone 4 16GB
MacBook Pro 15"
ned úno 17, 2008 10:19 pm
Callipo | ned lis 30, 2008 9:57 pm
presne to sem udelal ja . a zaloha probehla z5 do telefonu vpohode, ale nic tam neni .. takze probehla, ale proste v telefonu stare data nemam .. :( takz enanic ..
čtv kvě 22, 2008 6:20 pm
Uživatelský avatar Gekko gecko | ned lis 30, 2008 10:00 pm
Co vsechno zaloha obsahuje? kompletni obsah uzivatelske pamet?
Zkusil bych to ale MACka jaksi nemam...ach jo :roll:
iPhone 5S 16GB Silver iOS 9.2
pon zář 22, 2008 3:20 pm
Uživatelský avatar pajap | ned lis 30, 2008 11:23 pm
pát dub 04, 2008 12:53 am
Garden | sob čer 27, 2009 1:22 pm
odpověď na problém ohledně opakovaného nastavování RSA je zde
http://groups.google.com/group/ibares/b ... e99be76eb#
je to chyba Cydie a je nutno dohrát malou drobnost. Po jejím nahrání vše funguje správně, potvrzuji.
virus | stř zář 09, 2009 1:30 pm
