Soft na evidenciu spotreby auta
Uživatelský avatar Arrow79 | pon srp 29, 2011 6:22 pm
Prosim, ma niekto skusenosti s nejakym softom na evidenciu spotreby auta? Na Win mam QuickMoto, som s nim spokojny, hladam nieco podobne pre Mac.
pon říj 27, 2008 7:01 pm
dmi | pon srp 29, 2011 8:48 pm
Re: Soft na evidenciu spotreby auta
Ja jsem moc spokojeny s timhle, pokud nevadi ze je to pro iPhone:
http://itunes.apple.com/cz/app/gas-log- ... 95275?mt=8
čtv zář 09, 2010 11:08 am
FruFru | úte srp 30, 2011 7:41 am
ja muzu doporucit tohle, je free
http://itunes.apple.com/cz/app/gas-mana ... 62326?mt=8
Finance
19.01.2021 12:25
Velikost: 26 MB
Hodnoceni: 4.39175
od 97 lidí
Pascal Meziat
Gas Manager 1.59
Designed for anybody owning one or more vehicles (cars, motorcycles, etc.), Gas Manager allows you to create a detailed dashboard with your fuel consumption, your gas expenses and the miles you have traveled.
For each vehicle, input your fill-ups in a matter of seconds, and keep track of the evolution of several parameters in different ways (overview, graphs or lists):
- gas consumption
- gas price
- mileage per month
- cost of gas per mile/kilometer
- mileage per gallon/liter
- mileage per euro/dollar/etc.
A carbon footprint can also be calculated, depending on the vehicle’s consumption. You will thus be able to assess the total mass of carbon dioxide (CO2) it produces, as well as the average value per day and per kilometer traveled.
Gas Manager also allows all these data to be exported and sent by e-mail directly from your iPhone as a CSV file (comma separated values, which can be opened and processed by Excel or any other spreadsheet program), should you feel the need to create your own personalized statistics.
You are able to input your fill-up history either manually or by importing a CSV file.
Gas Manager also provides you with a Tools section, which enables you to geolocate your current position or your parking spot in a single click, so you can easily go back there later using a GPS guiding function or Google Maps. This tools section can also help you find various services around your location: gas stations, garages, restaurants, hotels and others.
The application automatically adapts itself to the units of measurement effective in your country: miles or kilometers for distances, and gallons, liters or KWh (electric vehicles) for fuel.
Freemium version, limited to 10 fill-ups by vehicle. Integrated purchase (IAP) unlocks unlimited fill-up creation.
Universal application with full resolution support for iPad.
čtv srp 06, 2009 2:54 pm
Uživatelský avatar Arrow79 | úte srp 30, 2011 10:38 am
Skor by som chcel soft pre Mac, nie pre iPhone. Dik
Zpět na Programy a hry pro Mac OS X
