Bluechart Adriatic (námořní mapy) pro iphone, existuje?
Mik-fx | úte črc 12, 2011 2:13 pm
Zdravím všechny, nevíte někdo zda existují námořní mapy jadranského moře pro Iphone? Rád bych to zakoupil, ale nikde jsem to nenašel.
díky za radu
Mik
Mik - fx
Mac Book Pro 15, Ipad mini 16 GB, Iphone 6S, ATV 2 JB, Time Capsule 3TB
pon lis 08, 2010 10:11 pm
Uživatelský avatar makatch | úte črc 12, 2011 5:30 pm
Re: Bluechart Adriatic (námořní mapy) pro iphone, existuje?
Pozri túto:
http://itunes.apple.com/us/app/transas-isailor/id398456162?mt=8#
Navigation
24.07.2025 13:06
Velikost: 63 MB
Hodnoceni: 2.5
od 6 lidí
Wartsila Voyage Sweden AB
Wärtsilä iSailor 1.12.2
Wärtsilä iSailor is an easy-to-use marine and river navigation application for amateur seafarers.
iSailor provides a clear presentation of navigational information, electronic charts and additional content.
TX-97 vector charts supported by iSailor are recognized worldwide as one of the most accurate and reliable sources of navigational information.
Chart folios can be purchased and downloaded in the iSailor Chart Store utilizing the standard iTunes Store payment/purchasing procedure. Chart correction service is provided on annual basis via the auto-renewable subscription service. iTunes will charge payment after confirmation of the chart correction purchase. You may manage your subscriptions and turn off the auto-renewal service in the Account Settings. Your subscription will automatically renew unless auto-renewal is turned off at least 24 hours before the end of the subscription period. You can cancel your subscription in the Chart Store any time. All previously purchased chart folios will remain available for you and can be restored from the service via the Chart Restore function. To receive subsequent chart corrections for your purchased charts, you will need to subscribe to the annual updates in the Chart Store.
The application works on iPhone and iPad using built-in GPS, NMEA Wi-Fi GPS or an external Bluetooth GPS.
Supported devices (iOS version 11 and higher):
• iPhone 5S or higher
• iPad 5 generation or higher
iSailor features:
• Positioning system: iOS (Built-In GPS), NMEA GPS or AIS Class B (Option)
• AIS Class A NavData interface (Option)
• NMEA Heading and Rate-Of-Turn sensors (Option)
• NMEA Echo Sounder with a graphical 2D echogram and water temperature sensor (Option)
• NMEA Wind Sensor, including True & Relative wind calculation (Option)
• NMEA Autopilot interface (Option)
• Display of charts, routes, track(s) and user objects
• AIS target presentation. Target contours and dimensions (Option)
• Internet AIS service (Optional subscription)
• Weather service (Optional subscription)
• Tides and tidal currents (Optional subscription)
• Sailing guides, regional marinas (Optional subscription)
• North Up, COG Up, Head Up and Route Up chart orientations
• Information on any vector chart objects
• Free cursor, Point-To-Point and Own ship referenced ERBL functionality
• Monitoring of navigational data: Position, Course (COG) and Speed Over Ground (SOG)
• Route creation by the graphic and tabular methods. “Go To” routes.
• Waypoint monitoring: Bearing to WP, Distance to WP, XTD, Time-To-Go and ETA
• Schedule information: Time-To-Go and ETA to any selected waypoint ahead
• Multi-language support
• Multi-unit support
• Custom track colors
• Day and night chart palettes
• Alarm monitoring functionality
• Route, track and user object: export/import via GPX, KML and KMZ formats
• Advanced Logging and Playback function (Option)
• User object sharing via Facebook, Twitter, iMessenger, eMail
NOTE: Continuous use of the GPS running in the background can dramatically decrease the battery life. Wärtsilä iSailor application may use your location even when it’s not open, which can decrease battery life of the device
iSailor EULA: https://www.wartsila.com/docs/default-source/marine-documents/transas/WVL-EULA.pdf
iSailor Privacy Notice: https://www.wartsila.com/legal-privacy/privacy
Questions? Please contact us at isailor.support@wartsila.com
Sincerely yours,
iSailor Team
iPhone6+,64GB,iOS 9beta3
ned pro 06, 2009 10:22 pm
Uživatelský avatar House_MD | úte črc 12, 2011 7:46 pm
radši si stáhni Male Karte... S přesností iPhone je to celkem o hubu, pokud tomu chceš věřit moc.
úte čer 09, 2009 12:41 pm
asd111 | úte črc 12, 2011 8:04 pm
dost se bojim ze sou dobré maximalně na plánovaní tras protože jestli se podle nich chceš řidit je to trochu blbost. jak asi víš na lodi každej metr muže být hodně velkej problém. na planovaní to bude stoprocentě dobré ale jinak asi k ničemu =)
Mik-fx | stř črc 13, 2011 5:35 pm
tak jsem koukal na ten isailor a je to celkem ok, za jadran chtějí 20 Eur což je vcelku v pohodě. Nic mméně já stejně dělám navigaci postaru tj. mapy a zapichovátko, ale je to celkem dobrý na plánování trasy a odhad doby dojezdu, na některých mapách co jsou k lodi nejsou kolikrát vyznačený rovnoběžky v jednotkách a někdy je to odhad jak z křišťálový koule. Ale u toho Isailoru se mi líbí že tam jsou celkem detaily jako v mapě, hloubky i jednotlivá nebezpečí, což u starších map na lodi kolikrát není. Díky za tip určitě se hodí
Mik
Mik - fx
pb318 | ned črc 31, 2011 6:06 pm
pozri sa na produkty Navionics (konkrétne Europe za 9,99eur), mne to vyhovuje, dá sa to použiť aj na seriózne účely.
pon lis 10, 2008 10:51 am
Mik-fx | úte srp 02, 2011 5:47 pm
Díky, už jsem si to stáhnul, vypadá to dobře, dobrej tip
Mik - fx
richard2 | úte srp 02, 2011 6:41 pm
Já jsem stáhnul toto
http://itunes.apple.com/us/app/marine-e ... 98822?mt=8
Na moři jsem zkoušel, vzhledem k výdrži baterie, jen chvíli, takže moc zkušeností nemám, ale s plotterem na lodi mapa souhlasila včetně všech navigačních nebezpečí.
EDIT: přehlédl jsem příspěvek pb318
iPhone 1.1.2 OOB -> HTC Diamond -> Asus P565 -> HTC TP2 -> iPhone 4 16GB -> iPhone 5 16GB -> BlackBerry Passport
iMac 21,5"
iPad 3 32GB 3G
Apple TV
stř led 16, 2008 8:21 pm
Zpět na Navigace pro iPhone
