Turistická mapa CR, Turistická mapa SR [Appstore free]
Uživatelský avatar iTukan | čtv črc 25, 2013 7:00 pm
Prozatím zdarma ke stažení dvě aplikace turistických map, ČR a SR, včetně zatím in-app na nahrávání tras.
Mapy v měřítku až 1:35 000, založeno na OpenStreetMaps.
Turistická mapa ČR - https://itunes.apple.com/cz/app/turisti ... 45835?mt=8
Turistická mapa SR - https://itunes.apple.com/cz/app/turisti ... 22786?mt=8
EDIT: Nedodal jsem, že krom vyhledávání by měly být mapy off-line.
Navigation
22.07.2025 22:06
Velikost: 1 GB
Hodnoceni: 0
od 0 lidí
Daniel Tekel
Turistická Mapa ČR 3.3
This application displays a detailed offline topographical map of Czech Republic with hiking trails, cycling paths, points, hills, etc. You can view it in 2D and 3D mode, now also with a satellite base map. You can record your tracks and the application will then render them on the map, calculate various statistics and height profiles. Recorded tracks are saved in GPX format and you can easily transfer them to your computer.
App's main features:
- displaying the current position on the map,
- 3D map display,
- hybrid satellite map,
- cycling map,
- your track recording,
- search on the map (requires an Internet connection),
- indicator of the iPhone's current orientation,
- GPS coordinates, altitude and GPS accuracy display,
- recorded tracks' statistics - distance covered, time, elevation gain,
- tracks height profiles rendering,
- recorded tracks are saved in GPX format and can be easily transferred to computer,
- track recording automatic shutdown after a specified time (e.g. 2 hours),
- track recording automatic shutdown if the battery level drops below a certain level,
- GPS accuracy setting (lower accuracy extends battery life),
- custom scaling for texts in the map (scale factor set in app's settings).
Map in this application was generated based on data from the OpenStreetMap project and this data is under (c) OpenStreetMap contributors. Map design and tiles are under (c) Daniel Tekel.
Important notice: The map in this application does not contain all existing hiking trails and points (currently covers approximately 90% of all trail)! For this reason, this application certainly cannot substitute an official hiking map. The author of the application assumes no responsibility for inaccuracies in the map. Terms of use of the app: https://www.apple.com/legal/internet-services/itunes/dev/stdeula/. Privacy Policy: https://turistickamapa.com/iOSPrivacyPolicy.html.
Navigation
23.06.2025 16:38
Velikost: 421 MB
Hodnoceni: 5
od 3 lidí
Daniel Tekel
Turistická Mapa SR 3.3
This application displays a detailed offline topographical map of Slovak Republic with hiking trails, cycling paths, points of interest, peaks, hills, etc. You can view it in 2D and 3D mode, now also with a satellite base map. You can record your tracks and the application will then render them on the map, calculate various statistics and height profiles. Recorded tracjs are saved in GPX format and you can easily transfer them to your computer.
- 3D map display,
- cycling map,
Uživatelský avatar speedman | čtv črc 25, 2013 7:48 pm
Re: Turistická mapa CR, Turistická mapa SR [Appstore free]
Super, vďaka.
Nevidím a preto nereagujem: smrdaky, leonko.
pát kvě 13, 2011 12:05 pm
shelbygt | ned črc 28, 2013 3:47 pm
Nahrávanie trasy už je spoplatnené
[b]MBP 16" i7 2,6 GHz ,SSD + 2x HDD
MBP 15.4'' C2D 2,53 GHz , SSD + HDD
iPad Mini 16 GB WiFi 8.3
iPhone SE 16 GB 12.1
iPhone 6 16GB 12.1
iPhone 6 16GB 12.1
iPhone 5 16GB 9.3
iPhone 4S 16GB 9.3
iPhone 3GS 32GB 6.1.6
pát črc 16, 2010 7:12 am
branok | úte črc 30, 2013 7:18 am
Ale celkom smiesnou sumou ...
úte říj 14, 2008 10:33 am
Zpět na Navigace pro iPhone
