VNC iPad
nasko | pát říj 17, 2014 6:07 pm
VNC iPad
Zdravím,
chtěl bych na svém iPadu zprovoznit VNC. Zajímalo by mě jaký program byste mi doporučili. Který požíváte vy? může být free a také placený. Také by mě zajímala možnost přes ten program PC zapínat a když už nejde zapnout, tak když bude zaplé PC ,tak abych mohl uspávat a poté zase používat. ( aby stolni PC nejelo cely den a šetřilo energii) ..
Díky
ned bře 09, 2008 8:15 am
ls8 | pát říj 17, 2014 6:09 pm
Re: VNC iPad
VNC nemá s uspáváním nic společného. Oficiální klient je https://itunes.apple.com/us/app/vnc-vie ... 19548?mt=8
Na uspávání a buzení, pokud to podporuje HW tvého počítače např. https://itunes.apple.com/us/app/inet-wo ... 96675?mt=8
Velikost: 9 MB
Hodnoceni: 4.76708
od 15053 lidí
RealVNC
RealVNC Viewer: Remote Desktop 4.9.4
RealVNC® Viewer from RealVNC® gives you instant remote access to your Mac, Windows and Linux computers from anywhere in the world. You can view your computer's desktop, and control its mouse and keyboard as though you were sitting down in front of it.
Download RealVNC Connect to each computer you want to control. Then sign in to RealVNC Viewer on your device using your RealVNC account credentials. You'll see your computers automatically appear; simply tap to connect.
RealVNC Connect password-protects each computer out-of-the-box. You may need to enter the same user name and password you use to log in to your computer. All sessions are then encrypted end-to-end.
During a session, your device's touch screen serves as a trackpad to give you precise control. Drag your finger to move the remote mouse cursor and tap anywhere to left-click (other gestures such as right-click and scroll are explained in-app).
As the original inventors of VNC remote access technology, we're confident you'll love what RealVNC Viewer has to offer. If you're still not convinced, check out our reviews!
===Key features===
- Connect with ease via our cloud service to computers running RealVNC Connect.
- Backup and sync your connections between all your devices by signing in to RealVNC Viewer on each one.
- A scrolling bar above the virtual keyboard includes advanced keys such as Command/Windows.
- Support for Bluetooth keyboards.
===Contact===
We’d love to hear from you:
iphone-support@realvnc.com
twitter.com/RealVNC
facebook.com/realvnc
Better still, leave us a review!
===Terms of Use===
https://static.realvnc.com/media/documents/RealVNCServicesTCs.pdf
===Trademarks===
RealVNC and VNC are trademarks of RealVNC Limited and are protected by trademark registrations and/or pending trademark applications in the European Union, United States of America and other jurisdictions. Protected by UK patents 2481870, 2479756; US patent 8760366; EU patent 2652951.
Velikost: 134 MB
Cena: US$ 2.99
Hodnoceni: 3.72727
od 11 lidí
BananaGlue GmbH
iNet WOL - Wake on Lan 2.6
iNet WOL is a tool to wake computer from sleep via a local network or the internet.
Its outstanding feature is its easiness of usage and the simple setup process.
With iNet WOL you can:
• Wake computer on the local network from sleep
• Wake computer via the internet
• Sleep, shutdown or reboot a computer remotely (Mac OSX only at the moment)
• Add new devices with one touch (need to enter MAC address since iOS 11)
iNet WOL scans the devices connected to your local network and shows them along with their name, IP and vendor at the tip of a button. You do not need to find out the MAC addresses or type them in. Just click on an item in the generated list to add it to your favourites.
Setup and usage:
Start iNet WOL and click on the device you want to wake up. Its that simple.
For more detailed setup instructions regarding wake on lan via internet please see our website.
Prerequisites:
• iPhone/touch has to be connected to your lan
• iPhone/touch have to be in the same subnet
• Computer and router are connected via ethernet cable
• Computers must be configured correctly for wake on lan
• Network cards must support the standard Magic Packet format.
Additional prerequitsites for WOL via internet:
• The network must be reachable via internet
• Router must be capable of forwarding wol packages
• Router and firewall must be configured correctly
Limitations:
Wake On Lan with subnet directed broadcasts is not supported in version 1.0. We will implement this feature in a future update. Wake On Lan currently works within the same subnet.
iNet WOL is also included in our network scanner iNet, alongside with other network tools like ping, Bonjour scanner, portscan and more.
If you just need a fast and easy solution for computer wake up - iNet WOL is perfectly suited for you.
Clon | pát říj 17, 2014 7:28 pm
Re: VNC iPad
Ja na startovani pc pouzivam app Wake https://itunes.apple.com/cz/app/wake/id396566137?mt=8
Uspavat snad uz muzes treba z toho VNC. Nebo treba misto VNC pouzivam iTeleport Pro
Velikost: 1 MB
Hodnoceni: 3.25
od 4 lidí
Dave Thompson
Wake 1.6.3
Wake is a professional networking tool that lets you start up PCs, Macs and Servers remotely. Compatible with all 'Wake On Lan' capable devices, Wake even gives you a status indicator to tell you whether each machine is on or off.
* Wake button sends 'Wake On Lan' magic packet to start up a machine.
* Works over wifi or cellular data network.
* Status indicator glows to tell you whether each machine is on or off.
* Automatically detects your computers for easy setup.
* Shake'n'wake - shake the device to wake all computers!
Typical Uses:
* Start up a machine remotely, then use VNC or other remote access service to view files.
* Monitor a list of business critical servers.
* Start up a classroom full of PCs from your desk.
For troubleshooting, go to davet.org/wake/support.html
stř črc 11, 2012 4:29 pm
Uživatelský avatar speedman | pát říj 17, 2014 8:11 pm
Re: VNC iPad
Používam Mocha VNC, vie aj wakeup.
Nevidím a preto nereagujem: smrdaky, leonko.
pát kvě 13, 2011 12:05 pm
Zpět na Všeobecně o iPadu
