Digits Calculator for iPad + iPhone
ls8 | čtv úno 24, 2011 9:52 am
Zajímavá kalkulačka pro iPad a iPhone (univerzální aplikace).
http://itunes.apple.com/us/app/digits-c ... 00115?mt=8
Velikost: 31 MB
Cena: US$ 1.99
Hodnoceni: 4.79133
od 1107 lidí
Shift
Digits Tape Calculator 3.1.2
Get organized! Conquer numbers on the go. Digits 3 is a top-to-bottom rewrite made for the latest iOS and devices.
We're human. We're busy. We make mistakes. So we designed a calculator for humans, from the ground up. Digits combines the editability of a spreadsheet with the simplicity of a calculator. Digits is a calculator a human can love.
So, why do so many humans love Digits? Its uniquely correctable tape means never worrying if you entered a calculation correctly. Make a mistake? Tap any entry on the tape to correct it (or edit, insert, copy and more). Then, add a label/comment and email or print the tape.
Digits is Shift’s highly-rated iOS calculator app that features an intuitive, fully correctable and editable line-by-line tape history. It uniquely provides spreadsheet-like editing with calculator-level simplicity. Tapes are stored as documents so groups of calculations can be stored and edited conveniently. Comments can be added to each calculation line, making the app ideal for expense tracking and budgeting.
Digits 3 highlights:
• An updated, polished user interface with buttery-smooth interaction.
• Dark Mode and detailed color and sound customization.
• Multi-threaded processing for desktop-level performance.
• In-app upgrades, starting with Tape Document sharing (via Messages, Mail, Dropbox and other popular file sharing services).
• Built from the ground up with support for 64-bit and the latest iOS/hardware.
• Designed to maximize resolution on devices like the iPhone X.
• Split View support on iPad for side-by-side work.
• Expanded in-app help.
• Accessibility VoiceOver support.
How Digits earned its stars:
• Spreadsheet-like editing with calculator-level simplicity.
• Fully correctable and editable line-by-line tape history.
• Fluidly enter values, label and email or print.
• Double-check and correct entries with ease.
• Export Tape Documents in a variety of formats.
Button functions:
Delete row, backspace, clear all, clear, memory, memory plus, memory minus, plus or minus, tape browser, percent, export, settings, shop, tips, help, edit, insert, total, copy, use, comment, flag, sin, cos, tan, square, cube, exponent, square root, cube root, root, inverse, Euler, Pi, add, subtract, multiply, divide, total.
Lincoln Six Echo | pát úno 25, 2011 9:07 pm
Re: Digits Calculator for iPad + iPhone (DNES FREE)
Včera jsem to náhodou stihl. Hned jsem si zavzpomínal jak jsem jako malý ťukal do páskové kalkulačky (hlavně ať vyjelo co nejvíc pásky :D )
pát čer 25, 2010 8:53 pm
Lincoln Six Echo | sob dub 16, 2011 3:45 am
Opět free!
Uživatelský avatar Golf | sob dub 16, 2011 9:17 am
Nevím kde vidíš free, já tam mám cenu... Možná to bylo včera, v pátek, i když si to postoval v sobotu.
iPhone X
MBA 2014 13" i5 8GB RAM
iPad Air 3 64GB LTE
Powerbeats Pro
Apple TV 2G + 4G
AW4 44
Mac mini 2018
sob bře 21, 2009 10:47 pm
Lincoln Six Echo | sob dub 16, 2011 10:49 am
Postoval jsem to hned, jak jsem to uviděl. Asi to bylo do 24:00 nějakého amerického času.
