AvPlayerHD
kotak | pon dub 04, 2011 9:14 pm
AvPlayerHD
AVPlayerHD je univerzální videopřehrávač pro iPad, existuje i verze pro iPhone. Dekodér je založený na balíku kodeků ffmpeg, poradí si se všemi obvyklými formáty videa.
http://itunes.apple.com/us/app/avplayer ... 76815?mt=8
Neví někdo jak docílit toho, aby se mi ukazovali i písmena s háčky a čárkami?:) Tyhle pismena to prostě vynechává:(
Entertainment
30.12.2020 18:08
Velikost: 53 MB
Cena: US$ 2.99
Hodnoceni: 4.0648
od 216 lidí
EPLAYWORKS
AVPlayerHD 2.95
Do you enjoy watching videos on your iPad? Do you hate not being able to because your iPad cannot support the video format? Or do you hate the inconvenient and time-consuming hassle of trying to convert video formats to fit into one that your iPad can support?
This is why the AVPlayerHD was created. The AVPlayerHD can play almost any computer video file format such as AVI, Xvid, WMV and much more clearly and effortlessly. No converting hassles. Just copy files via USB and just drag and drop into the AVPlayer’s Media Explorer.
The AVPlayerHD can also support external subtitle files such as SMI and SRT. So if you enjoy watching videos on your iPad, then the AVPlayerHD is an absolute necessity.
• Video Format Extension
- Support High quality video clips ( 720P, 1080P )
- Dolby Digital (AC3), Dolby Digital Plus (EAC3)
- MP4,MOV,M4V
- XVID,AVI,WMV,RMVB,ASF,H264,MKV… most of all movie file formats.
- SMI, SRT, TXT, SubStationAlpha Subtitles
• Post Processing
- High quality video processing
- Contrast,Saturation
- TV-Out
• Control the playback speed (From 0.5X to 2.0X)
- User setting support
-Sweep to the left : move to backword 10 sec
-Sweep to the right : move to forward 10 sec
-Sweep to the top : 1.5X speed
-Sweep to the down : normal speed
• Additional features
- Supports Split View
- Supports Picture in Picture mode ( h.264 format with H/W decoding )
- Rotation Lock / Aspect ratio Control
- Folder Management:Pass code/Move/Rename/Create
- Resume play from last position
- Scrubbing search
- supports e-mail attachment by "Open In" feature
• USB/WIFI Transfer
• Note
1. How to add video with USB
- Run iTunes 9.1 or above
- Device->My Device(My iPad)->Apps, drag and drop files to the AVplayerHD's documents
2. Support High quality video clips ( 720P, 1080P )
- High quality video clips of 720P (1280 x 720) or more are recommended for MP4 format.
- MP4, MOV, M4V formats that QuickTime supports can be played up to 1080P by using H/W Decoder but, Post Processing function isn’t provided.
- Support H/W decoding for MKV and AVI (720P supported on iPad1, 1080P supported on iPad2 / The New iPad)
- Hybrid decoding mode is added and now it is able to play high resolution videos by using hardware accelerator feature embedded in iPhone/iPad even for mkv or avi in h264. Also battery use time has extended.
- Application may crash in iPhone 3GS / iPod Touch due to heavy use of memory in Hybrid decoding. Try turning off all application running in background and reboot the device by holding down sleep mode button for long time.
- If screen shakes it means hardware decoding is not supported. Try turning off hybrid decoding.
- When the file formats are available for MKV or AVI the player supports hardware decoding.
- If you cannot choose audio in mp4 or avi, change the extension to mkv temporarily and chosen audio channel will be applied.
3. The optimal speed when advancing its playing speed can differ depending on the way it’s compressed and the size.
Video clips of XVID (AVI) 720 x 480 can be fast played up to 1.3-1.5 times faster than normal.
ls8 | úte dub 05, 2011 7:38 am
Re: AvPlayerHD
Titulky uložit v UTF8 kódování.
kotak | úte dub 05, 2011 8:57 am
Re: AvPlayerHD
Ok. Díky:)
Uživatelský avatar Petrt | úte dub 26, 2011 10:28 pm
Re: AvPlayerHD
Dnes vysla nova verze (1.4) chlubici se podporou dual core v ipadu2. Mohli by majitele teto aplikace napsat, zda lze diky tomu prehrat 720p mkv (x264) plynule? Diky.
ned srp 24, 2008 12:45 pm
ls8 | stř dub 27, 2011 8:24 am
Re: AvPlayerHD
Otestováno na Top_Gear.16x04.720p_HDTV_x264-FoV.mkv, v pohodě. Zvuk se mi zdá malinko posunutý proti obrazu, ale asi bych si toho nevšiml, kdybych se na to extra nesoustředil.
gulii | stř dub 27, 2011 8:48 am
Re: AvPlayerHD
Na čem jsi prosím testoval? iPhone?
sob pro 26, 2009 4:26 pm
Uživatelský avatar Slimák | stř dub 27, 2011 8:52 am
Re: AvPlayerHD
Vzhledem k tomu, že update přináší podporu dvoujádra, kterým je vybaven pouze iPad 2, tak logicky testoval na iPadu 2 (viz. podpis), jinak by o tom nebyla řeč. :roll: Na 3GS by to asi netestoval :crazy:
stř črc 02, 2008 1:28 pm
ls8 | stř dub 27, 2011 9:04 am
Re: AvPlayerHD
AVPlayerHD je pouze pro iPad. Takže ano, testováno na iPadu 2.
Uživatelský avatar Maximus-CZ | stř dub 27, 2011 11:26 am
Re: AvPlayerHD
jen dotaz, MKV má nějakou konstantní bitrate? ptž jestli ne, tak je to celkem šumák, že to má 720p, když to může mít bitrate jak 420p avi..
btw, nejsem ironickej, fakt se ptám:)
iP 4 Konečně doma!!
iPad 2 16 GB WiFi White 7.0
pát srp 01, 2008 7:29 pm
ls8 | stř dub 27, 2011 11:32 am
Re: AvPlayerHD
Uvnitř HD MKV je obvykle video kódované nějakým H.264 kodekem (např. x264), tedy stejné, jako se používá v MP4/M4V souborech pro iTunes, tedy obvykle s proměnným bitratem. Ten soubor, na kterém jsem to testoval, měl 1.56GB na hodinu. Tedy celkový průměrný bitrate 3385kbit/s.
Uživatelský avatar Petrt | stř dub 27, 2011 12:26 pm
Re: AvPlayerHD
Děkuji všem za reakci. Pokud do brzké doby nevyjde update Buzze, tak o tomto přehrávači budu taky uvažovat...
Uživatelský avatar Reyn | sob dub 30, 2011 11:14 am
Re: AvPlayerHD
Dokaze stejne jako Buzz prehravat filmy ze sitoveho disku (nas) pres nejaky protokol ? Premyslim o koupi a tohle je jedno z povinnych kriterii.
čtv lis 29, 2007 5:50 pm
ls8 | čtv zář 29, 2011 2:08 pm
Re: AvPlayerHD
Vyšel update, lze zakázat zálohování uložených videí v AVPlayerHD v iTunes.
http://www.eplayworks.com/2011/09/avpla ... pdate.html
niky79 | čtv zář 29, 2011 2:36 pm
Re: AvPlayerHD
A co 1080p video? To nezvladne? (jen pro zajimavost, nepredpokladam, ze bych do iPADU cpal 1080p).
ls8 | čtv zář 29, 2011 2:39 pm
Re: AvPlayerHD
Nezkoušel jsem, ale můžu zkusit. HD (720p) je v pohodě. Poradí si vůbec filesystem iOS se souborem o velikosti 8GB, což je obvyklá velikost filmu ve fullHD kvalitě?
Uživatelský avatar Pr3dator | čtv zář 29, 2011 3:06 pm
AvPlayerHD
ls8: Nemusí to byť film, môže to byť aj nejake 20 min. video.
Taky tady http://spravodaj.madaj.net/.
____________
Moje zariadenia:
stř zář 15, 2010 7:28 pm
Mazna | pát zář 30, 2011 8:25 am
Re: AvPlayerHD
Full hd nezvladne, film se prehrava, ale seka se. Takze spis to nezvladne ipad jako takovy
sob srp 06, 2011 6:40 pm
Mazna | pon říj 03, 2011 6:04 pm
Re: AvPlayerHD
Hoj,
Ve slozce inbox jsem mel nekolik videi, ale proste zmizely, jine slozky jsou ok. Stalo se to taky nekomu? Lze to nejak obnovit?
Drummer_CZ | pon říj 03, 2011 6:10 pm
Re: AvPlayerHD
Přátelé, umí tenhle přehrávač udělat playlist ? Mám ho, ale ani boha jsem nepřišel jak na to. Mám v iPadu dětem na cesty různé seriály ( hlavně krátké - večerníčkovské ) a zatím musím vždy pouštět jeden po druhým. Pevně věřím, že jde o problém mezi židlí a tabletem a nikoli ten, že je AVPlayer neumí :-)
Pokud umí, můžete mě "nakopnout" kde je hledat resp. jak ten playlist udělat ?
Díky moc za Vaše případné odezvy
Apple iPad 3G 64GB
Apple iPad 4 WiFi 64GB
Apple iPad Air 2 WiFi+LTE 128GB
Apple iPod Classics 120GB
stř bře 10, 2010 12:43 pm
ls8 | pon říj 03, 2011 6:34 pm
Re: AvPlayerHD
V nastavení lze nastavit, aby se automaticky spustilo další video v adresáři, podle abecedního pořadí. Používám to taky pro děti do auta, jede pak jeden díl večerníčku za druhým. :)
Settings -> Auto Play Next Video
Drummer_CZ | úte říj 04, 2011 2:46 pm
Re: AvPlayerHD
Is8 : Díky moc - to jsem v nastavení úplně přehlédl. Ano je to tak a funguje to. Sice to není ten správný playlist, jak by jsem si představoval, ale rozhodně to je zlepšení o 90%. Snad vývojáři zapracují v dalších verzích na standardním playlistu třeba formou "checkboxů". Jdu je inspirovat emailem :)
Ještě jednou díky
Apple iPad 3G 64GB
ls8 | pát říj 21, 2011 10:20 am
Re: AvPlayerHD
Za naprosto geniální považuju možnost této aplikace nastavit libovolná multitouch gesta téměř libovolným funkcím. Já jsem si nastavil:
swipe up = volume +10%
swipe down = volume -10%
swipe left = back 10s
swipe right = forward 1min
single finger tap = pause/play
double finger tap = show/hide menu
Tahle aplikace je prostě pecka, nejlepší přehrávač videí pro iOS.
Uživatelský avatar Petrt | pát říj 21, 2011 2:39 pm
Re: AvPlayerHD
ls8: no hlavně imho jediný použitelný. Mám nakoupeny všechny hlavní a žádný nepřehraje 720p mkv plynule jako tento ;-)
Uživatelský avatar Alek13 | sob říj 29, 2011 11:03 am
Re: AvPlayerHD
Jak to funguje? Jak tam davate videa?
Chci to koupit/premyslim
Diky
iPhone 3GS
iPad 2
iPhone 4S
Macbook / 2010 / SSD / OS X 10.9.
iPhone 5
pát říj 02, 2009 1:15 pm
ls8 | sob říj 29, 2011 11:11 am
AvPlayerHD
Videa se tam vkládají stejně jako do všech obdobných aplikací. Tedy buď přes iTunes File Sharing (v iTunes nebo nějaké aplikaci tupu DiskAid), nebo po lokální síti bezdrátově.
Uživatelský avatar Alek13 | sob říj 29, 2011 11:16 am
Re: AvPlayerHD
Hezky, urcite to chci. 3 dny mam ipad, moc toho neznam
iPhone 3GS
iPad 2
iPhone 4S
iPhone 5
Uživatelský avatar jennydrums | stř črc 11, 2012 10:12 am
Re: AvPlayerHD
Můj postřeh na new iPadu - video ve formátu .flv rozlišení 1920x1080 nejede úplně plynule. Stejně tak jsem měl něco v .mkv nevím teď přesně jaké rozlišení to bylo, nicméně v průběhu přehrávání, tu a tam se zaškubalo ale jinak v pohodě.
Jaké máte zkušenosti s tímto přehrávačem? Má s některými různě kódovanými videi problém?
úte říj 27, 2009 12:33 pm
niky79 | stř črc 11, 2012 11:30 am
Re: AvPlayerHD
Alek13 píše:Jak to funguje? Jak tam davate videa?
Diky
Ja tam davam obycejna avicka (ale ty prehraje kazdy prehravac i na iPAD1) a sem tam nejake to 720p. Ale tech moc ne – hlavne proto, ze mam jen 32 GB a proste to misto zabira :( Nerad to rikam, ale pro tyto ucely by se fakt hodila levna pametova karta.
Uživatelský avatar Petrt | stř črc 11, 2012 8:14 pm
Re: AvPlayerHD
jennydrums: je to muj primarni prehravac videi a jeste jsem nenasel zadne, ktere by nejelo. Mam ale v drtive vetsine jen scenove veci. Tusim je to snad jediny prehravac, ktery prehraje plynule vetsinu (u me vsechny) 720p MKVcka. FullHD jsem snad ani nezkousel.
Ad .flv videa ve FHD - nevim jake presne video jsi zkousel, ale mel jsem nejake dospelacke a s nima mel problem i muj Mac (tim myslim pocitac ;-) ), takze bych veril, ze s nima muze mit iPad problem (ale nevim jaky kodek byl pouzit).
Uživatelský avatar Pr3dator | ned zář 23, 2012 11:49 am
Re: AvPlayerHD
Neviete prečo nie je v US AppStore a kedy tam znova pribudne, prípadne je v SK AppStore?
____________
Moje zariadenia:
Uživatelský avatar Petrt | pon zář 24, 2012 3:39 pm
Re: AvPlayerHD
On už není ani v českém Appstore. Ale je prej v Malaysian store :-). Důvody jsem nedohledal a to ani na homepage.
Uživatelský avatar Pr3dator | pon zář 24, 2012 5:14 pm
Re: AvPlayerHD
A aká je prosím ťa homepage? Google nepomohol. :(
____________
Moje zariadenia:
mefistos | pon zář 24, 2012 6:44 pm
Re: AvPlayerHD
Nejaka nahrada? Chtel sem to koupit a neni to tam:-/ jeste to mam na mobilu :D ale to neni hd
Taky tady http://spravodaj.madaj.net/ HD
Uživatelský avatar Petrt | pon zář 24, 2012 6:53 pm
Re: AvPlayerHD
Pr3dator píše:A aká je prosím ťa homepage? Google nepomohol. :(
Homepage je tato www.eplayworks.com, ale v News neni o stazeni ani slovo a stejne jako tobe, ani mne Google detaily nerekl.
Doufam, ze je to jen docasne. Uz jednou jsem doplatil na nezalohovane ipa jedne hry (StoneLoops of Jamaica).
Uživatelský avatar Pr3dator | pon zář 24, 2012 9:49 pm
Re: AvPlayerHD
Dík, tak som im napísal na support, uvidíme či odpíšu.
____________
Moje zariadenia:
mefistos | pon zář 24, 2012 10:58 pm
Re: AvPlayerHD
Nic ja psal ohledne update na ios6 tejden zpatky a furt nic.. Co sem se docetl na netu tak nekdo psal ze mu odepsali a prej se nepohodli s apple na nejakejch podminkach a tak je stahl z app store.. A nevi se kdy a jestli vubec se tam vrati
