Semitethered Jailbreak pre iOS5
Uživatelský avatar Max87 | ned říj 23, 2011 8:12 am
What is a semi tethered jailbreak?
The semi-tethered jailbreak will allow you to reboot on the road, but with limited functionality. It is enough that you are no longer stranded, and you can use your phone, text, and many other features. This is just until you get home and can use redsn0w again to “just boot tethered”. Once you do that, you’re back to fully functional state.
To use Semitethered Jailbreak, simply do the following:
Step 1: Tether Jailbreak your iOS 5 device with RedSn0w
Step 2: Add "http://thebigboss.org/semitether" to your Cydia sources
Step 3: Install SemiTether and reboot!
That’s it. Now you can reboot your iPhone, even away from your computer!
As mentioned, there are a few pluses and minuses though.
-Phone will reboot to Home screen
-Can use every stock app on iPhone except Mail and Safari until boot tether
-Can’t use Cydia, or any jailbreak apps and tweaks until boot tether
-Phone can take longer to boot
Here is a summary of what you can and cannot do when in semi-tethered reboot state:
Can use phone, sms (text messages)
Can use every other stock app on iphone.
Cannot use mobile safari
Can use other appstore web browsers such as atomic web browser
Cannot use mail app. You could install a gmail app from appstore or such instead.
You cannot use any jailbreak tweak, app, cydia until you boot tethered.
While in the semitether booted state, you should not add a jailbreak ios5 notification such as sbsettings to notifications during this state or your device will be stuck in a respring loop until you get home to “boot tethered”.
prebrate z jedneho fora a z http://thebigboss.org/semitethered-jailbreak
Kto to bude skusat, skusa na vlastne riziko - nenesiem ziadnu zodpovednost za uvedeny postup a nemam to odskusane.
neviem, ci sa to niekomu z Vas bude hodit, ale myslim, ze sme o krok blizsie k untether JB...
Zobrazit video na http://youtu.be/3dffbLvAPpM
Kód do fóra: [youtube]3dffbLvAPpM[/youtube]
P.S: Ak to bude niekto skusat, napiste, ci funguje iBooks. v tom navode je pisane, ze funguje kazda stock app... Thx
Naposledy upravil Max87 dne ned říj 23, 2011 8:49 am, celkově upraveno 2
- iPhone X 256GB, iOS 11.1.2
stř črc 14, 2010 12:05 am
Uživatelský avatar Freaders | ned říj 23, 2011 8:15 am
Re: Semitethered Jailbreak pre iOS5
To je divny ale me to takhle funguje i kdyz tu apku nemam :D
iPhone SE 64GB Space Gray
Moto 360
Xiaomi Mi Band
iPhone 5C 32GB Blue
iPhone 4S 8.1.3
pát lis 06, 2009 4:31 pm
Uživatelský avatar Max87 | ned říj 23, 2011 8:20 am
no ak mas iP 4 s iOS 4.2.1 (ako to mas napisane v profile), tak sa ta to netyka pretoze mas untethered JB :)
na iPad neviem, nemam, neskusal som ani Redsnow...
Uživatelský avatar Searcasey | ned říj 23, 2011 8:31 am
Me se telefon nezapne..JB pres redsnow
Xbox 360 Elite No Flash 120 HDD
Iphone 5s 64GB iOS 7.0.4 JB
čtv črc 02, 2009 8:17 am
Uživatelský avatar susman | ned říj 23, 2011 8:32 am
Taky mi to nenajede.
iPhone 6s+ iPad mini 2
sob led 16, 2010 2:15 pm
Uživatelský avatar Max87 | ned říj 23, 2011 8:34 am
tak asi zostaneme pri tethered jailbreaku od Redsnow a pockame na oficialny untethred...
niky79 | ned říj 23, 2011 9:19 am
Freaders píše:To je divny ale me to takhle funguje i kdyz tu apku nemam :D
Ano. Když Uděláš jen jb, ano. Ale jakmile tam hodis nekteré pokrocilejsi věci, jako sbsetting, tak uz to nenabehne. To platí pro ios5 a redsnow.
Uživatelský avatar Freaders | ned říj 23, 2011 9:28 am
me to nabiha normalne -ipad 1 ios5 GM ...nenabehne jen kdyz to je restart z cydie
Moto 360
Xiaomi Mi Band
iPhone 5C 32GB Blue
iPhone 4S 8.1.3
Uživatelský avatar dodulo | ned říj 23, 2011 10:44 am
je to hlupost, urcite to neinstalujte, su s tym len problemy staci si len precitat komenty na fb stranke redmondpie
http://www.facebook.com/RedmondPie
ono to fungovat teoreticky moze do chvile kym cez Cydiu nedoinstalujete nejaky tweak, ktory hlbsie zasahuje do systemu (sbsettings, winterboard...) takze urcite neodporucam skusat to, rano ked som to zbadal, tak ze wooow super idem do toho, len ze pockam na par skusenosti a je to tu nic z toho nebude
sob čer 28, 2008 1:29 pm
Uživatelský avatar offlines | ned říj 23, 2011 2:22 pm
Mě to jede v pohode. Potřeboval jsem restore, tak jsem to otestoval a vse jede jak ma. Muzu vypnout a zapnout iP bez pc s Jaibreakem. Super
Icq: 242 677 315
mail: offlines@me.com
skype: offlines
pát zář 03, 2010 4:24 pm
Uživatelský avatar dodulo | ned říj 23, 2011 2:47 pm
ake veci mas nainstalovane zo Cydie? To je tiez myslim hodne dolezity udaj.
Naposledy upravil dodulo dne ned říj 23, 2011 2:51 pm, celkově upraveno 1
petros666 | ned říj 23, 2011 2:49 pm
Ja to nainstaloval,pote me to Cydia chtela jeste updatnout a to uz neprobehlo,hlasi to error.
I am here: http://maps.google.com/maps?ll=49.903483,18.356745
pon dub 25, 2011 5:50 am
xslide | ned říj 23, 2011 8:07 pm
Mně to funguje naprosto jak má!
sob led 19, 2008 12:37 pm
munku | ned říj 23, 2011 8:25 pm
funguje super
Uživatelský avatar dodulo | ned říj 23, 2011 10:45 pm
chlapi ta hlaska ze mne to funguje je dost bezcenna kedze nevieme co mate vo svojich iPhonoch zo Cydie nainstalovane, komu to funguje prosim pripojte k tomu aj zoznam apps co mate zo Cydie, vdaka
Endys111 | pon říj 24, 2011 9:18 am
Prý problém vzniká při nainstalování [zakázáno].
http://www.biteyourapple.net/index.php/ ... per-ios-5/
Uživatelský avatar dodulo | pon říj 24, 2011 11:27 am
konecne normalna odpoved, vdaka, cize s kludom by som do toho mohol ist no keby som vedel kedy bude vydany normalny untethered...asi predsa len nejake 1-2 tyzdne pockam, ak nie skusim toto, lebo iOS 5.0 ma velmi laka :) no urcite chcem aspon SBSettings na to som uz navyknuty :) kedze v scrollovacej liste na iOS je iba pocasie a to ma nezaujima
inak ti, co tu pisali sa pravdepodobne sami udali :D
xslide | pon říj 24, 2011 11:31 am
Mám nainstalováno UI Settings, 5 icon dock, iBlacklist, DeleteMail a tento program funguje perfektně!
stZ | pon říj 24, 2011 1:27 pm
dodulo: mam pocit, ze si to muzes v klidu nainstalovat.....nechci malovat certa na zed, ale untJB hned tak nebude a jestli vubec. Tak jasne slibu je spousta......ja nenadavam JB je zdarma, pokud nebude tak se taky nexxxxx :)
iPad 1 Wi-Fi 32 GB , 5.1.1 iOS JB
iPad 3 Wi-Fi 64 GB , 8.4.0 iOS JB
iPad Air 2 Wi-Fi 64 GB, 8.4.0 iOS JB
iPhone 6s Plus 128GB Space Grey
MB Pro, MB White
AW Sport 42mm
stř úno 06, 2008 12:25 am
stZ | pon říj 24, 2011 1:38 pm
Presne tak to je.... vypnes tel, ale pokud nejsi u PC apon si zavolas :D
MB Pro, MB White
AW Sport 42mm
Endys111 | pon říj 24, 2011 2:31 pm
MODERÁTOR BEAVERS VARUJE:
Příspěvek smazán, obsahoval informace o warez aplikaci.
Naposledy upravil Endys111 dne pon říj 24, 2011 3:06 pm, celkově upraveno 1
moramiki | pon říj 24, 2011 2:48 pm
Endys111.a co aktualizuje ????hmmm
Uživatelský avatar ABAB | pon říj 24, 2011 5:02 pm
Tak já to také vyzkoušel a iPhone se chová stejně.Bez PC nenajede vůbec. Mám spoustu app např. Sbsettings,Winterboard......
iPhone 11 Pro black 64GBiOS 13.1.3
iPad AIR 2 64GB Wi-Fi+4GiPadOS 13.1.3
ned dub 10, 2011 9:00 pm
Endys111 | pon říj 24, 2011 5:24 pm
Endys111 píše:
Nevim co na tomto příspěvku byl warez,obsahoval pouze informaci o aktualizaci Semitethered,v čem byl aktualizován a odkaz na stránku kde jsem to nalezl.Jestli toto je warez,tak potom o čem je celé toto téma.
Uživatelský avatar yesi | pon říj 24, 2011 5:33 pm
dodulo píše:kedze v scrollovacej liste na iOS je iba pocasie a to ma nezaujima
Kuk sem
Zobrazit video na http://youtu.be/jhAnqkDIig0
Kód do fóra: [youtube]jhAnqkDIig0[/youtube]
dodulo píše:inak ti, co tu pisali sa pravdepodobne sami udali :D
S tymto ste fakt trapni. Co vas do toho, ze kto pirati a kto ne?
iPhone 5 32GB • iOS 7.0.3
pon srp 02, 2010 6:44 pm
Uživatelský avatar Barberry.pha | pon říj 24, 2011 5:37 pm
VAROVÁNÍ MODERÁTORA:
at si warezi kdo chce, ale zde na foru se to neresi!! Precti si to v pravidlech fora.
Uživatelský avatar dodulo | pon říj 24, 2011 6:10 pm
@yesi: mal som na mysli, bez jailbreaku, keby toto "power center" iOS obsahovalo defaultne tak je pre mna jailbreak zbytocny, niektore drobnosti by som uz ozelel ako napr. dorucenky, no uz len kvoli tomuto si fon jailbreaknem
Uživatelský avatar alias | pon říj 24, 2011 9:10 pm
OT: ja si radsej pockam na untethered jailbreak.. povodne som tiez chcel ist do toho semi-tethered, ale co ja viem :| neni to az take spolahlive podla toho co som cital..
[iPhone 7 - 32GB - iOS 11]
čtv kvě 05, 2011 2:33 pm
blesk88 | stř říj 26, 2011 1:39 pm
caute a toto semitethered funguje nemusim sa bat dajte mi sem nejaky navod ako na to a ozaj pojde mi [zakázáno]
MODERÁTOR jackherrer VARUJE:
ban!
pon úno 15, 2010 6:04 pm
Uživatelský avatar Max87 | stř říj 26, 2011 7:07 pm
Update #2
What's New:
● Reworked the ***** conflicts
● Reworked daemon loading order to hopefully solve 2 issues.
1) Reboot after 2 mins on some devices
2) ****** with itunes issue on some devices.
Note: This version now takes 60-90 seconds after reboot and it will respring again then your device should be usable.
P.S : za hviezdicky si dosadte jednu app z cydie.
P.S2: pre moderatorov - tie hviezdicky som dal schvalne
k0mk0 | stř říj 26, 2011 10:06 pm
ja debil som si to dal na môj iPT 4g bez toho aby som zase čítal, nič to nerobí :ROFL: prdele
Uživatelský avatar oPicka | čtv říj 27, 2011 11:33 am
OT: untethered asi jětě pořád nic že?
někdo tady psal, že to je otázka chvíle a já furt sleduju a nic ..
čtv čer 18, 2009 9:53 pm
Uživatelský avatar vermut | pát říj 28, 2011 10:11 am
Tak potvrzuju na mým iPhonu nefunkčnost, sice pokud je připojenej k pc tak se ukáže ale nenabootuje vůbec obrazovka - zasekne se na na "točícím se kroužkou" :-(
iPhone 2G 8GB - probíhá renovace....
iPhone 3G 16GB
iPhone 4 16GB Black
iPhone Xs 64GB Gold
IPad 2 16GB White
IPad Air 16GB Space Grey
pon lis 03, 2008 5:50 pm
Uživatelský avatar dodulo | ned říj 30, 2011 1:54 pm
dalsi update, po restarte telefonu bez PC by uz malo fungovat aj Safari
http://www.redmondpie.com/jailbreak-ios ... pod-touch/
EDIT: po instalacii verzie 0.9.1 sa na springboarde objavi aplikacia s nazvom "semitether" po otvoreni treba kliknut na tlacidlo fix a telefon by v pripade restartu mal nabootovat, mne to nejde :(
kruspe | ned říj 30, 2011 8:38 pm
Tak jsem to zkusil a k mému překvapení nelze just boot now přes redsn0w ... :-D takže bduu muset restore :-D to mámf akt radost to tam dávat všecko znova :-D
smejky | ned říj 30, 2011 9:09 pm
Zkousel jsem to taky, jeste pred poslednim updatem a taky mi to zamrzlo na restartu, nabutovani pres redan0w uz neslo. Nastesti pomohlo udelat jaillbreak znova a ikdyz to hodilo na konci chybu tak nasledny just boot uz prosel! Nevim co to dela, mozna Iconoclasm nebo FolderEnhancer kazdopadne to uz nezkousim :)
iPhone 5S 64GB, fw 8.1
iPad air 3G 32GB, fw 8.1
iPad Mini Retina 3G 32GB, fw 7.2.1 JB
MacBook Pro 13"
pon srp 25, 2008 11:11 pm
kruspe | ned říj 30, 2011 9:15 pm
Je to na prd musím mít customfirmware ... takže všecko budu dělat znova :-D všechny aplikace ze cydie prostě všechno ... to mě teda pěkně sejří ...
EDIT: seme mi funguje jak má ... ale chci používat celej JB .. a just boot now nejde ...
iphonelama | pon říj 31, 2011 10:33 am
Zdravím chlapáci, asi ještě není custom FW iOS5 s haktivací, nebo něco podobného že?
iPhone 3G iOS 4.3.2 JB
iPhone 4 iOS 5.0.1
iPad 2 iOS 6
čtv dub 28, 2011 7:38 pm
Uživatelský avatar dodulo | úte lis 22, 2011 10:34 pm
bol som donuteny spravit restore na 5.0.1 tak som znovu skusil semitether, kedze som uz neinstaloval tolko veci zo Cydie ( mam iba MultiCleaner, terminal, OpenSSH, SBSettings ) a uz mi telefon po restarte nabehne :), predsa sa clovek citi trosku istejsie, ze keby nieco
petrzelka | stř lis 23, 2011 5:02 pm
Zdravim,mam stejny dotaz jako prede mnou,nevite kdy bude Custom FW 5.O ? :)
Je to docela dlouha doba...
úte bře 29, 2011 3:43 pm
