USB pristup do iphone pres Total Commander
iphonelover | sob led 12, 2008 1:24 pm
o moznosti dostat se do adresarove struktury iphonu pres USB kabel za pomoci Total Commander se tu uz nekde psalo, ale nejaky podrobnejsi navod chybel...takze tady je alespon anglicka verze...
To install:
First get t-pot. The most recent version at the time of this writing is: http://t-pot.googlecode.com/files/T-PoT.0.2.zip
Home page: http://code.google.com/p/t-pot/
t-pod is a plugin for an application called total commander.
Download and install Total Commander from: http://www.ghisler.com/download.htm
After Total Commander is installed, unzip t-pot to a folder. Run Total Commander and goto "Configuration/Options" in the file menu. Goto "Plugins" and then click the "WFX" menu button. "ADD" the t-pot's .wfx file that you unzipped. After adding it to Total Commander, close Total Commander, and load it again. T-pot should now be installed.
To use:
Connect the iPhone/iTouch via USB.
At the top of the two window panes is a drop down menu usually labeled [-c-]. Select Network Neighborhood [--] from it. Choose t-pot from the window pane. You should now be looking at the file system of your iPhone/iTouch. Now you can drag over files from the two window panes to each other.
funguje to a prenos dat je mnohem rychlejsi nez pres wifi!!!
pát pro 14, 2007 9:58 am
Julek | ned led 13, 2008 2:12 pm
Už je to v návodech o chvilku dříve než tvůj topic, ale protože jsi se pěkně rozepsal doplním to tam.
4.4.08 Úklid v sekci, přesun do archivu. Julek
pát říj 12, 2007 9:32 pm
cardy | pát lis 21, 2008 4:26 pm
Re: USB pristup do iphone pres Total Commander
pls help me
nejak se mi nedari neni nahodou potreba mit instalovanes ten debilni soft itunes
tpot v totaci mam ale nedostanu se do iphone
thx
pon pro 17, 2007 5:50 pm
Uživatelský avatar Beavers | pát lis 21, 2008 7:27 pm
cardy píše:pls help me
thx
Ještě jednou narazím na podobně laděný příspěvek a s touto grafickou úpravou tak to bez varování mažu. Zanech zloby a vyjadřuj se zde slušně. Toto je fórum slušných lidí a ne nějaký pokec s kámošema. Pokud chceš tímto způsobem komunikovat, přesuň se do jiného fóra, kde najdeš sobě podobné. Beavers.
úte črc 01, 2008 3:17 pm
