iP:~ root# ps -ax
PID TTY TIME CMD
1 ?? 1:11.60 /sbin/launchd
12 ?? 0:31.17 /usr/sbin/mDNSResponder -launchd
13 ?? 1:02.40 /usr/sbin/notifyd
14 ?? 2:22.59 /usr/sbin/syslogd
15 ?? 8:42.20 /usr/sbin/configd
18 ?? 0:00.71 /Applications/MxTube.app/MxT2d
20 ?? 0:19.62 /usr/sbin/update
21 ?? 3:30.66 /usr/libexec/lockdownd
24 ?? 0:52.38 /System/Library/PrivateFrameworks/IAP.framework/Suppor
25 ?? 0:04.42 /usr/sbin/fairplayd
29 ?? 2:19.31 /System/Library/PrivateFrameworks/CoreTelephony.framew
30 ?? 0:13.24 /usr/sbin/BTServer
1449 ?? 0:19.58 /usr/sbin/mediaserverd
1450 ?? 1:15.93 /System/Library/CoreServices/SpringBoard.app/SpringBoa
1458 ?? 0:02.22 /var/stash/Applications/MobilePhone.app/MobilePhone
1459 ?? 0:13.10 /var/stash/Applications/MobileMail.app/MobileMail
1618 ?? 0:21.53 /var/stash/Applications/Installer.app/Installer
1621 ?? 0:00.55 /System/Library/Frameworks/SystemConfiguration.framewo
1625 ?? 0:02.85 /usr/sbin/sshd -i
1632 ?? 0:00.10 /usr/libexec/amfid
1626 ttys000 0:00.20 -sh
1634 ttys000 0:00.02 ps -ax
iP:~ root# top
Processes: 20 total, 1 running, 19 sleeping... 77 threads 00:49:03
Load Avg: 0.04, 0.08, 0.04 CPU usage: 0.93% user, 7.41% sys, 91.67% idle
SharedLibs: num = 0, resident = 0 code, 0 data, 0 linkedit.
MemRegions: num = 2384, resident = 25M + 0 private, 21M shared.
PhysMem: 24M wired, 31M active, 7956K inactive, 63M used, 19M free.
VM: 495M + 0 199840(0) pageins, 1315(0) pageouts
PID COMMAND %CPU TIME #TH #PRTS #MREGS RPRVT RSHRD RSIZE VSIZE
1661 top 7.4% 0:09.98 1 17 52 596K 856K 1368K 12M
1626 bash 0.0% 0:00.66 1 13 56 412K 860K 1612K 13M
1625 sshd 0.0% 0:03.08 1 14 38 376K 1336K 1444K 13M
1621 SCHelper 0.0% 0:00.93 4 47 79 572K 1416K 1292K 14M
1459 MobileMail 0.0% 0:15.89 9 182 276 4984K 11M 8776K 68M
1458 MobilePhon 0.0% 0:02.43 2 79 176 1720K 9308K 3836K 60M
1450 SpringBoar 0.0% 1:29.78 13 269 571 6476K 11M 12M 77M
1449 mediaserve 0.0% 0:19.74 7 157 147 1464K 1784K 2988K 19M
30 BTServer 0.0% 0:13.28 2 118 97 1020K 2380K 1304K 27M
29 CommCenter 0.0% 2:19.78 8 104 102 1136K 1584K 1648K 19M
25 fairplayd 0.0% 0:04.42 1 33 67 540K 1416K 864K 15M
24 iapd 0.0% 0:52.63 7 111 165 1480K 4056K 1868K 30M
21 lockdownd 0.0% 3:30.76 3 61 100 1124K 2380K 1612K 26M
20 update 0.0% 0:19.75 1 13 43 224K 624K 232K 11M
18 MxT2d 0.0% 0:00.71 1 24 123 944K 3804K 972K 26M
15 configd 0.0% 8:43.76 5 164 126 1016K 1628K 1504K 16M
14 syslogd 0.0% 2:23.09 4 37 36 340K 248K 460K 13M
13 notifyd 0.0% 1:02.72 2 260 28 240K 248K 288K 12M
12 mDNSRespon 0.0% 0:31.19 2 46 67 572K 1404K 884K 14M
1 launchd 0.0% 1:11.79 3 78 35 304K 248K 408K 12M
Uživatelé procházející toto fórum: Bing [Bot], Google [Bot]
