1.1.2. OTB UNLOCKED!!!
m.horra | pát led 18, 2008 6:43 pm
Konečně dobrá zpráva pro majitele iPhonů verze 112 OTB!!!
First of all, HUGE thanks to TA_Mobile and IMTH for getting us the secpack from 1.1.3 Also, thanks to psp_sully for giving me a 1.1.2 OTB phone to play with. Without them there would be no unlock, and no blog post.
YOU VERY WELL MAY BRICK YOUR PHONE WITH THIS. Be careful. I have done it sucessfully on two phones, and have never bricked an iPhone in my life.
So lets get down to business. It is a hardware method to downgrade the bootloader, and I am assuming you are familiar with the old hardware method, so I won't repeat steps. You need to have a 1.1.2 4.6 phone for this to work. If you upgraded to 1.1.3, have fun waiting for 1.1.4!
First download this pack, you will need these files. This includes the NEW secpack, a new ieraser, a new testcode.bb, and a new iunlocker.
1. Copy all the files to a directory on your phone. It is imperative you do not shut off the phone after ieraser, or you cannot restore wifi, since the only fls which works on 4.6 is 1.1.3
2. Run ienew. This is ieraser, and it erases your 1.1.2 firmware to allow the testpoint to work.
3. Find an old 3.9 nor dump and create a file called "nor" with the first 0x20000 bytes of the old nor dump. This is the 3.9 bootloader.
4. Copy "nor" into the folder and run iunew. This is iunlocker and runs just like the old one. You will need the A17 testpoint on before running this. See Step 3 for info on this testpoint.
5. The bootloader is now 3.9!!! Run bbupdater or restore phone with the AnySimmable firmware of your choice.
6. Run AnySim and, as usual, enjoy your unlocked iPhone.
PS. Thanks again to TA_Mobile and IMTH. The secpack was the only obstacle to the unlock. And thanks to the girl who pressed the return button while I held the testpoint :)
odkaz:
http://iphonejtag.blogspot.com/2008/01/ ... ocked.html
Uživatelský avatar waczko | pát led 18, 2008 8:04 pm
Nechci se Ti do toho vměšovat, ale toto téma již zde je. Přiště se trochu více dívej....
http://forum.iphone.cz/viewtopic.php?t=1188
:roll:
A to že jsi to sem dal v AJ stejně moc lidem nepomůže. Alespon jsi mohl napsat, že se jedná o HW unlock :lol:
iPhone 2G 8GB -> iPhone 3G 8GB Black -> iPhone 4S 16GB White iOS 5.0.1
iPad 16GB WiFi + 3G: iOS 4.3 -> iOS 4.3.1 JB -> iOS 5.0.1
WebDeveloper
POMOZTE!! SBÍREJTE, NAKUPUJTE x) http://goo.gl/mJEzc
pon pro 24, 2007 6:07 pm
Julek | pát led 18, 2008 8:13 pm
Mno takže lock a pokračujte dál v té první diskuzi.
Úklid v sekci, přesun do archivu. Julek.
pát říj 12, 2007 9:32 pm
