UNLOCK BEZ SIMKY JE TU!!!
OneWayCZ | pát led 25, 2008 8:32 pm
Takže lidi je na světě unlock bez turbo sim karty. Mam ho doma. Jen je potřeba přeložit z angličtiny návod jak na to. Je tu někdo schopný to pčeložit? Odměna je odblokace pomocí tohoto software.
UNLOCK 1.1.2 (windows)
________________________________________
*This will fully unlock iPhone (1.0.2 virgin or virginized and working 1.1.1) to work with any network with functional YouTube.
*know issues for US iPhone users outside US http://code.google.com/p/iphone-elite/w ... e_sms_apps
*No Known issues for US iphone for US users.
*This will not virginize or UnBrick you phone so start with a working virginized 1.0.2 or any working 1.1.1.
*OF COURSE YOU NEED WI-FI.
*this method was used on a US originally 1.1.1 OTB (not sure it would work on 1.1.2 OTB, I don't see why not). So it should work on 1.1.1 OTB and lower for sure.
*This guide is for EXPRIENCED users only, you should know how to use winSCP or FileZilla, and know how to move files from and to iPhone before using this Guide.
*it is best to have those files handy:
- Firmware 1.0.2 and 1.1.1 and 1.1.2
- iTunes 7.4 (7.5 didn?t work for me) "in pack"
- iBrickr v0.91 "in pack"
- iAsign "in pack"
- anySIM 1.2u "in pack"
- lockdown 1_1_2 "in pack"
- Filezilla ftp (winSCP didn?t work for me) "in pack"
- WiNnstaller "in pack"
- AppTappinsaller "in pack"
- 1.1.2_jailbreak "in pack"
You will also need 2 sim cards one AT&T non-activated card and a T-Mobile sim card (or any Non-AT&T)
The Cycle
* From 1.1.1 or 1.0.2 ==UPDATE==> 1.1.2 ==DOWNGRADE==> 1.0.2 ( this will put modem firmware 04.02.13_G @ 1.0.2)
* Jailbreak/activate/unlock in 1.0.2
(this will unlock modem firmware 04.02.13_G @ 1.0.2) ===UPGRADE====> 1.1.1 then jailbreak/oktoprep (this will prep for 1.1.2 jail breaking)
* update to 1.1.2 then jailbreak/activate ===> you will get activated and unlocked modem (04.02.13_G) @ 1.1.2
PLEASE READ THE WHOLE PRE_GUIDE BEFORE STARTING!!!!!!
Step 1. (Update to 1.1.2.)
Start with connecting you iphone with any AT&T SIM in it (not the one legally activated) to iTunes and sync, then press update, this will update your phone to 1.1.2 and you modem to (04.02.13_G), when it is done a picture of a plug will appear on the iphone and it will tell u to slide to unlock in Gibberish, on iTunes it will tell you, that you need iTunes 7.5 or higher to activate you phone.
Step 2. (Downgrade to 1.0.2)
While the iPhone is still connected to iTunes ,Put the iPhone in DFU mode (by pressing sleep and home button till you phone turns off and the screen turns black release only the sleep button, keep holding the home button till iTunes recognizes the phone on Restore mode). iTunes will offer you to restore the phone, you press Shift and Select restore, a browser window will pop up, browse where you have your 1.0.2 firmware and highlight it then click ok, and wait for it to be done.
Step 3. (Downgrade to 1.0.2)
When the restore is done an error message will appear click ok, the phone will have the yellow triangle on it, Start iBrickr v0.91 it will offer you to boot the phone, click boot then go to main menu, if the screen turns green you need to redo the 1.0.2 restore, if red, wait about 40-50 seconds and the phone will restart and you will get the " Activate " screen.
Now you have an iPhone firmware 1.0.2 with modem firmware (04.02.13_G), so take a break
Step 4. (Jailbreak/activate/unlock)
A. Using WiNstaller(will close iTunes automatically) and the unactivated AT&T SIM in the phone, click Activate ( This will jailbreak/Activate )and wait till its done , then you see phone activated press ok then you will see your springboard. Open appTappinstaller on you computer and chose firmware 1.0.2 then install the Installer.app ( the blue Icon in the Iphone SpringBoard you will see later) then it will restart and wait for it to go back on main springBoard.
B. Connect to Wi-Fi and click the Blue Installer icon, and wait for it to refresh, it will tell you that it found an update, click install and after its done click the home button and wait for the iphone to do a soft reset then slide to unlock.
Using the same method install Community Sources+ BSD Subsystem+ OpenSSH in that order and click the home button and wait for the soft reset after each install.
C. Restart the phone and with change the SIM to a T-mobile SIM or any other NON-AT&T SIM, then go to settings>general>autolock>never then press home button.
Open FileZilla ( or winSCP) then connect to your phone ,the first try will take about a minute to connect put your IP address where it says (example Ip. 192.168.0.100)
Host: 192.168.0.100
Username: root
Password :dottie
Port:22
Open anySIM 1.2u rename the folder inside it to anySIM.app then copy the anySIM.app folder to /Application/ to your iPhone (I assumed you know how to work with SCP ) and set permissions on both anySIM folder and the anySIM file inside the folder on your iPhone to 755 on fileZilla ( Octal 0775 on Winscp ) then restart your phone.
D. After the restart you will see the anySIM icon with a red lock on your springboard don?t click it yet .Using WiNnstaller we will activate the T-mobile SIM (in my case) by clicking Activate, after its done click on the anySIM red icon and wait for it to be done( takes about 5-7 min). after its done it should be able to tell if your phone was unlocked successfully. IF NOT redo step number 4.c carefully.
If that didn?t work means you did not follow instructions and you have to revirginize your base band the start over if that went will ,we will activate again with iAsign using windows commands, go to start>run>cmd a black command window will pop up, change directory to where you installed iAsign in my case on c:\ , so cd c:\iAsign then press enter then type ( iasign --automatic iPhoneActivation_private.pem ) after its done it should say activated, wait about a minute and see if you got signal on the phone with the NON_AT$T sim, if not just restart you phone. and you will.
****** if you got here congrats. you unlocked baseband (04.02.13_G)*********** so take a break
E. Connect to iTunes and sync if you have to, so u can get to the main iPhone Screen, then press SHIFT + UPDATE not restore and browse to firmware 1.1.1 then chose and press ok, wait for it to finish , iTunes will display and error press ok then take phone off DFU mode using iBrickr, Open iBrickr and chose to boot then go to main menu , if the screen turns green you need to redo the 1.1.1 update USING SHIFT AND RESTORE not update , if red , wait about 40-50 seconds and the phone will restart and you will get the " Activate " screen .
Step 5. (jailbreak/Oktoprep)
A. Assuming that you got the "activate" screen close iTunes and slide to unlock to the emergency keypad , dial *#307# the phone will ring then press back space to clear the numbers, then press 1 then dial, the phone will ring again, press answer the press hold , the phone will ring again press dismiss , then go to contacts, add 2 contacts, one is: name p and url prefs://1f and the other is j url http://jailbreakme.com, save them and go in contact p and click on prefs://1f, this will take to set up you Wi-Fi, make sure you are connected to Wi-Fi and press home button, this will take you to "activate" screen , slide to unlock then dial 1 the phone sill ring , answer and press hold , it will ring again then press dismiss , that will take to contacts, select contact j and press on url http://jailbreakme.com . this will open the browser to AppSnapp Webapp site just chose " Install AppSnapp" and wait about 2 minutes , the phone will restart and you have a jailbroken 1.1.1.
B. Don?t worry if you are not getting signal on you phone , you are not suppose to on Firmware 1.1.1 .Now click the Blue Installer icon, and wait for it to refresh, it will tell you that it found an update, click install and after its done click the home button and wait for the iphone to do a soft reset then slide to unlock.
C. Open iTunes, Sync or setup if you have to and make sure you are on the main screen with update and restore buttons available. NOW on your phone click installer ( blue icon) and install Oktoprep it is under tweaks 1.1.1. and wait for it to say it is ok, then press home button and wait for a soft reset.(( do not restart phone ))
Step 6.( update to 1.1.2)
A. On iTunes press update . it will update your phone to 1.1.2 without errors , wait for it to finish, a picture of a plug will appear on the iphone and it will tell u to slide to unlock in Gibberish, on iTunes it will tell you, that you need iTunes 7.5 or higher to activate you phone.
B. close iTunes and open 1.1.2_jailbreak folder and click windows.bat , java application will open, MAKE SURE YOU CHECK INSTALL SSH. if a message popped up saying " this is only for phone with oktoprep" you need to Restore back to 1.1.1 and start back at step number 5, if it worked just wait for it to finish, press ok then restart the phone. You will see that the phone will reboot by its self after u restart it NOW YOU HAVE A JAILBROKEN 1.1.2
If you use the latest 1.1.2 you dont have to patch lockdown any more , new 1.1.2 jailbreak activates too so ( no need for last step ), Use the one in the packet or download it here http://conceitedsoftware.com/iphone/site/112jb.html
C. ( only use with 1.1.2 jailbreak in pack see step above) open FileZilla ( winSCP didn?t work for me at this point ) then connect to your phone ,the first try will take about a minute to connect put your IP address where it says Host : 192.168.0.100 in my case , Username: root , password :alpine and port:22 ,on you computer open the lockdown 1_1_2. On you phone go to /usr/libexec/ and rename the lockdown file in /usr/libexec to lockdownd.bak the copy the lockdown file from lockdown 1_1_2 to /user/libexec on your phone and set permissions on it to 755 on fileZilla ( Octal 0775 on Winscp ) then restart your phone.
########## Congrats you have an unlocked iPhone with Firmware 1.1.2 #########
Uživatelský avatar mylan | pát led 25, 2008 8:34 pm
A preto si to tu musel dať hneď trikrát? :?
pon lis 05, 2007 11:16 am
Uživatelský avatar j.v. | pát led 25, 2008 8:57 pm
spam Spam SPAM!
Tohle je už mnohokráte provařený unlock 1.1.1 OTB (a nižších) které se pouze updatují na 1.1.2 >:(
iPhone 8GB gen1 | Nějaké ty Androidy | BB Passport
MacBook Pro 13" | 10.10 | SSD
pát říj 12, 2007 11:01 am
Wamer | pát led 25, 2008 9:01 pm
_____________________________________________________
* Kompletně unlockne iPhone pro práci se všemi sítěmi a YouTube
* Známé problémy pro US iPhone v zahraničí
* Nejsou žádné známe problémy pro US iPhony používané v US
* Nevirginizuje nebo unBrickne tvůj iPhone, takže začni s virginizovanou 1.0.2 nebo s 1.1.2
* Tato metoda byla použita na US originální 1.1.1 OTB (mělo by fungovat na 1.1.2 OTB, nevidím důvod proč by nemělo). Takže by to mělo fungovat na 1.1.1 OTB a nižších.
* Tento průvodce/návod je pouze pro zkušené uživatele, měl by jsi vědět jak používat WinSCP nebo FileZillu a vědět jak přenést soubory z nebo do iPhone před tím, než použiješ tento návod.
* Vhodné soubory:
    * Firmware 1.0.2, 1.1.1 a 1.1.2
    * iTunes 7.4 (7.5 u mě nefungovalo) "v balíčku"
    * iBrickr v0.91 "v balíčku"
    * iAsign "v balíčku"
    * anySIM 1.2u "v balíčku"
    * lockdown 1_1_2 "v balíčku"
    * Filezilla ftp (winSCP u mě nefungovalo) "v balíčku"
    * WiNnstaller "v balíčku"
    * AppTappinsaller "v balíčku"
    * 1.1.2_jailbreak "v balíčku"
Také budeš potřebovat 2 sim karty. Jednu neaktivovanou AT&T a jednu T-Mobile kartu (nebo další neaktivovanou AT&T)
// dělal jsem to jen na rychlo a už musim zase dělat něco jiného, někdo to po mě opravte a zkuste mi s tím pomoct :) budu se to snažit dodělat hned jak to pujde :)
j.v. píše:spam Spam SPAM!
Takže to už nemusím překládat?
Uživatelský avatar spachal_tmp | pát led 25, 2008 10:36 pm
Opet opakuji, sledujte 'oficialni' Status Ticker http://docs.google.com/View?docid=dgzw9xs_0gfhxns. Zadne zazraky se nekonaji ..
úte pro 11, 2007 4:54 pm
Julek | pát led 25, 2008 11:36 pm
Dávám to do archivu.. zatím jak říká Spáchal... nic se nekoná..
pát říj 12, 2007 9:32 pm
