Update Modem firmware
Johnnny | stř čer 10, 2009 1:45 pm
Zdravim
Dnes som tu an fore videl navod ako odblokovat iPhone pre vsetky sim. *Mam ho jailbreaknuty na 2.2.1 ale modem firmware je 02.30.03. Ten potrebujem dostat na 02.28. Neviete ako by som to spravil ?
ls8 | stř čer 10, 2009 1:49 pm
Re: Update Modem firmware
Johnnny | stř čer 10, 2009 3:07 pm
nejaky navod som nasiel...aleniekdenakonci to skolabovalo... nedal by sa sem prosim napisat podrobnejsi navod ? v iPhonoch som uplny laik
Uživatelský avatar spachal_tmp | stř čer 10, 2009 7:50 pm
Pokud mas baseband verze 5.8, zkus z Cydie program 3G Baseband Downgrade (http://forum.iphone.cz/viewtopic.php?f=1&t=16305)
úte pro 11, 2007 4:54 pm
Johnnny | čtv čer 11, 2009 6:40 am
no, to je problem, BootLoader mam 5.9 .... a co sompozeral vraj to zatial nejde zmenit... alebo uz ano ?
Uživatelský avatar dodo_mt | čtv čer 11, 2009 6:45 am
Nie zatial sa neda odblokvat. Treba pockat na FW 3.0 pocitam ze sa vsetci budu sustredit na odblokvanie prave tohoto FW.
dodo
Apple iPad 32GB Wifi White
Apple Keyboard (Wireless)
Apple Magic Mouse
sob čer 28, 2008 2:44 pm
Johnnny | čtv čer 11, 2009 6:54 am
aha..takze ostava stary navod
To downgrade your iPhone 3G?s 2.30 baseband:
1. Download pHasebandowngrader here.
* Download to Desktop
2. Connect via SSH to your iPhone
* Open MobileTerminal
* Type ?login?
* Default login/pass is root/alpine
3. Copy the downloaded ?phasebandowngrader? folder to your iPhone?s ?Applications? folder
* The folder MUST named phasebandowngrader with lowercase letters!
* Type ?cd / Applications/phasebandowngrader/?
4. Execute pHasbandowngrader
* Type ?./phasebandowngrader?
5. You should now be running iPhone baseband 2.30!
nasiel som toto, lenze od casti "Open MobileTerminal" robim mozno nieco zle
open terminal len zapnem, ten phasebandowngrader prenesiem rucne a potom zadam v terminali vo WinSCP "./phasebandowngrader" lenze tam to blbne, proste to nejde a v mobile terminal tiez nie...co robim zle ? fakt som v tomto laik, takze neviem ci to robim dobre..resp co robim zle
Dik
