Problemy s FW 3.0 redsn0w - nemam signal
eMPiko | sob čer 20, 2009 9:20 pm
Zdravim,
skusal som s redsn0w JB nahodit FW 3.0, ale mam problem, aj napriek tomu ze prebehne uspesne, nenachadza mi iphone ziadnu siet (T-mobile Slovensko SIM). Skusil som teda stiahnut a nahodit original 3.0, ale iTunes mi asi v polke Restore nahodi error 14 a dalej sa s tym neda pohnut. Skusal som restartnut PC-cko, reinstalovat iTunes, zapojit USB priamo do MB, ale nepomaha, vsetko co mozem nahodit je ten custom.
Ak mate nejake napady ako na to, resp. ak viete preco mi nenachadza tu siet, sem s tym.
Dakujem
jardo | sob čer 20, 2009 9:52 pm
Re: Problemy s FW 3.0 redsn0w - nemam signal
kdesi bolo upozornenie ze sa ten new jail...nema pouzit na blokovane pristroje.ja mam tiez lock s t mobilu a radsej pockam ako sa to ustali
kills | sob čer 20, 2009 10:20 pm
If you are using a 3G iPhone with yellowsn0w and rely on yellowsn0w to obtain cellular service, then you should NOT use redsn0w right now.
citaj...http://blog.iphone-dev.org/
eMPiko | sob čer 20, 2009 11:06 pm
No, problem je v tom, ze ja yellowsnow nepouzivam a iphone ani nemam unlocknuty.
jardo | sob čer 20, 2009 11:28 pm
MOZE MI TO NIEKTO STRUCNE PRELOZIT?NEVIEM ANGLICKY.DIK Yellowsn0w in its current form will NOT work with the baseband version that is present in the 3.0 update, you will need Ultrasn0w, which will be released sometime soon, Ultrasn0w will work with all iPhone 3G models (but not 3GS), even ones that were previously unlockable, Ultrasn0w (when available) will be released via APT (this means you will be able to get it via Cydia or Icy
eMPiko | sob čer 20, 2009 11:39 pm
Yellowsnow v sucasnej podobe nefunguje s basebandom uvedenym v update 3.0, budete potrebovat ultrasnow, ktory vydame uz ciskoro. Ultrasnow bude fungovat so vsetkymi iPhone 3G modelmi (ale nie 3GS), dokonca aj s tymi unlocknutymi. Ultrasnow bude vydany cez APT, cize sa bude dat stiahnut skrz Cydiu al. Icy.
slososk | ned čer 21, 2009 9:07 am
Moja zena ma tiez iphone blokovany na t-mobile a stiahol som tu na fore
fw 3.0 custom a vsetko funguje oki... Tak skuste to
habitat3 | pon čer 22, 2009 9:05 am
kdy se tedy muze pocitat s tim, ze vyjde ultrasnow..?? Diky
Uživatelský avatar jursat | pon čer 22, 2009 3:44 pm
slososk píše:Moja zena ma tiez iphone blokovany na t-mobile a stiahol som tu na fore
Ano, ale ked mas kupeny iPhone z vonku, tak sa ti neaktivuje operator. Ja mam tiez Orange a ide to bez problemov, pretoze sa ti aktivuje cez SIMku, ale skus tam dat inu SIMku, napr. Orange, alebo O2 ci ti pojde a daj vediet, pretoze T-mobile ma blokovane iPhone.
iPhone 5s Gold 64 GB Telekom SK, iOS 7
sob kvě 10, 2008 8:38 pm
sakal_dv | úte čer 23, 2009 6:08 pm
Mne najprv tiež nechitilo signál ale na druhý pokus my našlo T-Mobil a všetko funguje 100%...skús ešte raz reštartnuť...
Uživatelský avatar De__Etroit | úte čer 23, 2009 9:33 pm
Ultrasn0w je venku, problém vyřešen, chce to LOCK..
Lock. dodo
iP 3Gs 32Gb 4.2.1 - ultrasn0w + iPad BB
úte čer 23, 2009 12:41 pm
