From Zibri's Blog:
"DO NOT UPGRADE TO 1.1.4
ZiPhone will work with 1.1.4.
But I need to FULLY test it and do a few
adjustments.
Stay tuned.
(If you do you won't get any support from here)"ZIPHONE WORKS!!!!! Nate True has reporetdly tried out ZiPhone on 1.1.4 and IT WORKS
scenic píše:Ja len taku malu otazku mam: Vieme co je nove vo FW 1.1.4??
drsny píše:a to na nem navic hodlam testovat cestinu o kterou vubec nestojim a kterou na telefonu rozhodne mit nebudu :-p
haasteren píše:Tak uz jeden clovek co jsem mu prodal IPHONU provedl UPGRADE. Uz nevim kam jim to mam napsat... Kazdopadne downgrade jde bez problemu takze zatim se nic vazneho nedeje. Ziphone jsem zkousel, primo na te 1.1.4 ale dopadlo to zamrzlim jablckemTakze zpet na 1.1.3 a je vse READY ...
crusader píše:Toto jsou údajně nové featury fw. 1.1.4. Vyplatí se Vám?
Some of the New Features
- Drag & Drop files using Windows Explorer
- New baseband 04.04.05_G
- Faster load time of Photos application and SMS application
- SMS out of order bug has now been fixed
- Safari no lunger dumps webpages when you open up a new page
- Phone loading time is faster overall
- Better reception
- Faster wifi also reported
