Poraďte někdo, rozchodil jsem telefon pres jailbreak, ale nemuzu rozchodi SIM, zkousel jsem AnySim a Sim Free a nic
This iPhone must be used with an approved SIM" Prosim poradte, propadam zoufalstvi
j.v. píše:Pokud je to 1.1.1 oob mela by stacit AnySIM 1.1
Pokud je to 1.1.2 oob a downgradnuty na 1.1.1 unlock zatim neexistuje
How To: Unlocked 1.1.1 ---->Update to 1.1.2--->Unlock with AnySIM1.2.1u
Yes Guys its POSSIBLE!!! I can confirm that its working. BUT proceed at your own risk!
If U have a working 1.1.1/04.01.13_G iPhone unlocked with AnySIM 1.1 this is what u need to do:
1. Run Oktoprep via Installer
2. Update to 1.1.2 via iTunes, after update leave iPhone connected till iTunes "see it" then close iTunes.
3. Jailbreak (http://conceitedsoftware.com/iphone/1.1.2-jailbreak.zip)
3.a Install BSD Subsystem via Installer
4. In Installer add rep.frenchiphone.com to your installer source and then Install anySIM 1.2.1u from the installer. Reboot iPhone!
5. Put the iPhone in Airplane Mode!!! Run AnySIM1.2.1u! After its completed, go to Settings--->Airplane Mode set to OFF, now u will get a signal bars!
6. If u're outside US, SMS and Phone its not working. To FIX IT install iWorld via Installer, choose your country. Viola! U're done! Enjoy free 1.1.2
If for some reason this method is not working for you, follow this to "get back" - http://iphone.unlock.no/#how-to-downgrade-1.1.2Step 6: Unlocking 1.1.2
Note:
# This version of anySIM works only with 4.02.13_G baseband version and can be run on 1.0.2, or 1.1.1 jailbroken systems
* The only way your baseband will be 4.02.13_G while you're running 1.0.2 or 1.1.1 is if you updated then downgraded firmware.
1) Start at 1.0.2 or 1.1.1 or 1.1.2, do a fresh 1.1.2 RESTORE
This will load the new baseband firmware.
2) Now, RESTORE (downgrade) first to 1.1.1 and then to 1.0.2.
This will not alter the baseband firmware, so it will still be the 1.1.2 version
3) Now on 1.0.2, jailbreak and install anySIM 1.2.1u
4) Run anySIM 1.2.1u to unlock the phone. Although you are running fw 1.0.2 with a 1.1.2 baseband, the phone will work.
5) Now RESTORE to 1.1.1 again
6) Do a jailbreakme.com and use installer to fetch and run OktoPrep
7) Now do an UPDATE (not restore) to 1.1.2.
If you restore instead of updating then oktoprep is wiped out and you need to redo the steps.
8) Run the UPDATED jailbreak software.
DO NOT RUN anySIM 1.2 under 1.1.2. It will not work properly and you risk corrupting your baseband.
Enjoy!
iphoneman píše:ionas píše:jaky FW? jestli 1.1.2. mas zatim smulu
1.1.1. (3A109) fakt to nejde nicim, co s tim?
spachal_tmp píše:Dokud budes mi v telefonu 04.02.13_G, tak si ani nezavolas .. Je nutne to nejdrive shodit na nizsi verzi, napriklad pomoci 'BB Downgrader (1.1.2)', najdes jej v repozitari http://i.unlock.no .
spachal_tmp píše:Pak asi nezbyva nic jineho nez cely proces projit znova... sry
