iOS 6.1 beta pre developerov
Uživatelský avatar makatch | čtv lis 01, 2012 7:17 pm
Oddnes (1.10.2012) dostupný pre developerov.Build: 10B5095f
Podporované zariadenia:
iPad Wi-Fi (3rd generation)
iPad Wi-Fi + Cellular (model for ATT)
iPad Wi-Fi + Cellular (model for Verizon)
iPad 2 Wi-Fi (Rev A)
iPad 2 Wi-Fi
iPad 2 Wi-Fi + 3G (GSM)
iPad 2 Wi-Fi + 3G (CDMA)
iPhone 5 (Model A1428)
iPhone 5 (Model A1429)
iPhone 4S
iPhone 4 (GSM)
iPhone 4 (CDMA)
iPhone 3GS
iPod touch (5th generation)
iPod touch (4th generation)
Upozornenie:
Devices updated to iOS 6.1 beta can not be restored to earlier versions of iOS. Registered development devices will be able to upgrade to future beta releases and the final iOS 6.1 software.
Novinky:
Map Kit Searches
The Map Kit framework now lets you programmatically search for map-based addresses and points of interest. The MKLocalSearch class initiates a search for map-based content using a natural language string. In other words, you can enter placename information or portions of an address and have Map Kit return search results that match the information you provide. For example, searching for the string “coffee” would return the location of local coffee bars along with information about each one.
Naposledy upravil makatch dne pát lis 02, 2012 8:50 am, celkově upraveno 2
iPhone6+,64GB,iOS 9beta3
ned pro 06, 2009 10:22 pm
Saddako | čtv lis 01, 2012 8:02 pm
Re: iOS 6.1 beta pre developerov
Nějaké informace co 6.1 přináší nebo odebírá?
stř čer 18, 2008 8:08 pm
pe.kova | čtv lis 01, 2012 8:24 pm
pouze Map Kit framework -> pro vývojáře
sob lis 24, 2007 10:29 am
Uživatelský avatar sheerONE | čtv lis 01, 2012 8:59 pm
takze nic extra noveho nieje v iOS 6.1 ?
iPhone 7 Plus 128GB Black
Macbook Air 13" early 2014
stř pro 23, 2009 2:19 pm
Uživatelský avatar Pr3dator | čtv lis 01, 2012 9:21 pm
Je to iba prvá beta, takže zatiaľ nie.
____________
Moje zariadenia:
stř zář 15, 2010 7:28 pm
Uživatelský avatar caesar | čtv lis 01, 2012 10:52 pm
To tam bylo uz ted. Jen to tlacitko nebylo tak velke. Navic muzou udelat tlacitko treba metrove, ale dokud nebudou zavadet nahlasene chyby do map, neni to o nicem. Uz 4 tydny jim hlasim zavaznou chybu na mape a zadna zmena
pon úno 11, 2008 5:37 pm
Saddako | pát lis 02, 2012 8:17 am
S opravama chyb v mapach je to opravdu spatne. Sam jsem hlasil moje vsechny dulezite adresy ktere jsou fyzicky jinde nez na mape a stale nic... Tento problem vsak nevyresi nova verze iOS.
PaDoX | pát lis 02, 2012 8:36 am
Samozrejme že sú aj iné novinky. Reportovanie problémov v mapách a menšia zmena na lockscreen obrazovke.
ikoala | pát lis 02, 2012 10:06 am
Reportování v mapách je i v 6.0, jen s mensim tlacitkem
sob srp 22, 2009 12:43 pm
Uživatelský avatar caesar | pát lis 02, 2012 7:04 pm
No vzdyt to pisu dva prispevky nad tebou!
vojikvo | ned lis 04, 2012 7:17 pm
Po aktualizaci mám ip celej v češtině, jen "odemknout" a "vypnout" mám v angličtině...stalo se to ještě někomu?
Uživatelský avatar Barberry.pha | pát lis 09, 2012 11:38 am
A mas zarizeni registrovane u nejakeho vyvojare?
Uživatelský avatar McJobs | pon lis 12, 2012 7:42 pm
iOS 6.1 beta 2 pre vyvojarov k dispozicii
http://9to5mac.com/2012/11/12/apple-rel ... evelopers/
úte zář 30, 2008 12:58 pm
Uživatelský avatar Colpeas | sob lis 17, 2012 11:56 pm
a konečně funguje panorama ;)
ned zář 20, 2009 9:26 am
Uživatelský avatar Gekko gecko | pon lis 26, 2012 12:19 am
Zdravim zdejsi diskutery,pouzivam zartim posledni iOS6.0.1 mam to i v profilu,pred chvili jsem si u nekterych clenu vsimnul, ze jiz v profilu maji verzi 6.1 a dopateal se az sem.
Je tedy stale jen beta 2 pocitam ze ano,jak z founu tak itunes mi to novejsi nez soucasnou nenabidne a kldy apple planuje finalni verzi, ma nekdo zpravu?
Developerskou registraci prozatim nemam, nikdy jsem se po ni ani u minulych idevices nepidil a tudiz ani nevim jak na to.
http://aapl.cz/velikost-ios-od-prvni-verze-do-posledni/
Tohle jste cetli? nevim zda to sem mohu takhle dat, jine tema me nenapada a pokec tu snad ani neni...
Lze jen dodat, ze ac iOS za tech pet let narostl temer desetinasobne, stale je vse rychle, hladke a absoluitne plynule, tak jako driv, navic perfektne stabilni...co vic si prat? snad jen to aby se takto naucili psat os i dalsi,ktere netreba snad jmenovat.
Pak je take pekne oznaceni/kodove jednotlivych verzi iOS ani jsem o tom nemel paru,mrknete: http://www.[BULVAR: odkazujte na jiné zdroje]/2012/01 ... stemu-ios/
Pokud sem dane vazne nepatri, poprosim o presun na patricne misto,dik.
iPhone 5S 16GB Silver iOS 9.2
pon zář 22, 2008 3:20 pm
rychlik | pon pro 03, 2012 7:56 pm
BETA 3 je vonku ... opravuje chyby
iPod Touch 2G 8GB --> iPhone 2G 16GB --> iPod Touch 4G 8GB --> iPhone 3GS 16GB --> iPad Mini 16GB WIFI --> iPhone 4S
iPad Mini Retina 16GB + iPhone 5C 8GB iOS 8
Windows 7 Professional SK 32bit
sob říj 03, 2009 8:34 pm
Uživatelský avatar Metalgirl | pon pro 03, 2012 8:11 pm
A které chyby, prosím?
Uživatelský avatar Ronaldok | úte pro 04, 2012 3:41 pm
Ja osobne sem zacal az s betou 3 a musim rici ze my system prijde mnohem sviznejsi oproti 6.0.1.
ned úno 03, 2008 7:55 pm
Uživatelský avatar Colpeas | úte pro 04, 2012 4:40 pm
hlavně mi pod 6.1 padají všechny aplikace na jízdní řády :-/ snad to B3 napraví.
Uživatelský avatar Petrt | sob pro 15, 2012 9:26 am
Prosím, fungují vám na této betě neoriginál Lightning kabely?
edit: Ronaldok - děkuji
Naposledy upravil Petrt dne pon pro 17, 2012 11:45 pm, celkově upraveno 1
ned srp 24, 2008 12:45 pm
Uživatelský avatar Ronaldok | pon pro 17, 2012 6:01 pm
ano fungují, jeden mam a používám
iphonevzen | pon pro 17, 2012 7:28 pm
beta 4 venku
stř pro 08, 2010 3:32 pm
Uživatelský avatar Ronaldok | úte pro 18, 2012 3:59 pm
jake změny?
Uživatelský avatar 2L8 | čtv led 03, 2013 4:55 pm
Podla tychto zdrojov, a navyse aj od jedneho znameho dobreho hackera i0n1c, tvrdia, ze uz do 2 tyzdnov tohto mesiaca januar vydaju oficialny iOS 6.1
Zdroj:
http://www.[BULVAR: odkazujte na jiné zdroje]/2013/01 ... o-mesiaca/
pát říj 24, 2008 6:16 pm
Uživatelský avatar speedman | ned led 13, 2013 7:22 pm
GM by malo byť k dispozícii zajtra, resp. budúci týždeň.
http://www.redmondpie.com/ios-6.1-gm-fi ... next-week/
Nevidím a preto nereagujem: smrdaky, leonko.
pát kvě 13, 2011 12:05 pm
Uživatelský avatar 2L8 | pon led 14, 2013 4:58 pm
Ale ked chceme JB, tak radsej neupdatujeme nie? :) Neviem, mozno sa mylim, ale tak sa mi za, ze pri niektrom JB sme museli mat nizsiu verziu iOS a az potom sa updatovalo ... TinyUmbrela pre zalohu este nic?
Uživatelský avatar benitoSVK | pon led 14, 2013 5:37 pm
No ja osobne updatovať nebudem ;-)
ned čer 07, 2009 4:52 pm
Tony | sob led 26, 2013 1:11 pm
ahoj, nevíte kdy už bude iOS 6.1 pro všechny uživatele?
čtv led 03, 2013 10:44 am
Uživatelský avatar miquel | ned led 27, 2013 4:52 am
Vonku je (celkom necakane) beta 5 ale build ID ma ako finalna verzia takze zaujimavy krok od Applu, co sa bude diat dalej? Hadam, ze 6.1 pre verejnost nie je daleko.
čtv črc 02, 2009 9:22 am
Uživatelský avatar Sphyn0x | ned led 27, 2013 10:42 am
Nechápem, čo tým chcú dosiahnuť. Mohli už rovno vydať public 6.1.
Uživatelský avatar Lukáš Valenta | ned led 27, 2013 11:06 am
Dělají to správně. Buď vydají verzi plnou chyb a lidé budou nadávat, nebo chyby dlouho opravují a lidé také nadávají. Já ale chci Apple, který vydá až potom, co opraví všechny chyby.
Sent from my iPhone 4S using Tapatalk
iPhone 5 64GB černý - iOS 8
stř bře 21, 2012 1:23 am
Uživatelský avatar Ronaldok | ned led 27, 2013 12:38 pm
Ale me telefon nenabídl jeste novou aktualizaci.
Uživatelský avatar caesar | ned led 27, 2013 12:40 pm
Telefon bety nenabizi
Uživatelský avatar Ronaldok | ned led 27, 2013 12:51 pm
I kdyz dam aktualizovat rucne tak mam zobrazeno ze mam aktualni verzi FW 6.1 (10B5126b)
Uživatelský avatar Aparat | ned led 27, 2013 1:36 pm
Nahraj si novou betu do telefonu rucne pres itunes..
Sent from my iPhone 5 using Tapatalk
stř srp 19, 2009 2:32 pm
tribula | pon led 28, 2013 6:56 am
Bravoooo... Gratulujem Applu. Po dlhej dobe vydaju novu Betu a potom hned na druhy den expiruje ta predosla!!! Sakra. Clovek jeden den neskontroluje update a na druhy den je hned rano velmi smutny ked mu zdochne phon...
Este raz Bravo apple
čtv čer 02, 2011 9:10 am
Uživatelský avatar vbruno | pon led 28, 2013 7:08 am
Doufám, že se tu rozčiluješ aspoň v pozici developera, který na 6.1 testuje své aplikace...
stř čer 11, 2008 7:52 am
Uživatelský avatar Colpeas | pon led 28, 2013 9:19 am
úžasné.
přes noc se mi locknul telefon, nejde aktivovat ani přes wifi ani 3G, iTunes kváká, že je software aktuální a restorovat nejde, protože jsou údajně "nedostupné servery".
za 99 dolarů ročně, co si platím, bych očekával, že svůj iPhone budu moct používat a né, že když Apple na poslední chvíli vydá novou Betu tak si budu muset shánět náhradní telefon abych se přes den aspoň někam dovolal.
E-maily evidentně přijímá, vibruje a pípá, ale já si je nemůžu přečíst! to se jim fakt povedlo!
Uživatelský avatar speedman | pon led 28, 2013 9:26 am
Colpeas, vyzerá to tak, že chceš telefón bežne používať. A neviem, či je beta s obmedzenou platnosťou nato zrovna určená.
jeenik | pon led 28, 2013 2:13 pm
Tak na 4S to vypadá, že wifi funguje lépe. Dosud jsem měl problém s občasným dlouhým časem než se načte stránka na webu.
ned úno 08, 2009 5:20 am
