jsem zoufalej prosim radu s winpwn
HFX9 | sob zář 13, 2008 6:24 pm
Mam iphone 2g nahrany fw 2.0.2 locknuty
Pokousim se celej den pomociWinpwn 2.5 si udelat svuj custom fw a nahrat ho do iphone.
Jenze vse probyha dobre az do chvile, kdy chce abych prepnul iphone do DFU modu, ridim se jeho radama a nakonec ukaze ze mi gratuluje ze iphone je v DFU modu, ale dal nic zustane to stejne i ctvr hodiny.
Reknete nekdo jak dlouho to ma trvat nez me vyzve abych pripojol iphone k itunes a pomoci shift+restore nahral ten svuj upraveny fw?
Kdyby byl nekdo tak ochotny a pomohl mi to vyresit treba pres icq budu mu neskonale vdecny, uz fakt nevim jak dal a navic ten telefon neni muj.
Prosiiiim pomoc nenechte me v tom
//EDIT
tady je vypis z logu winpwn ktery je videt pri zapnutem rezimu expert
Expert mode turned on!
iPhone device selected
Starting IPSW building
Hashing IPSW...
Matching IPSW in C:\Program Files\winpwn-2.5\FirmwareBundles\... (61de6a2b...)
checking: C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle\Info.plist
Preferred root size is:800
Found Bootloader 3.9
Found Bootloader 4.6
Firmware/all_flash/all_flash.m68ap.production/DeviceTree.m68ap.img3 (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/DeviceTree.m68ap.patch)...
encrypted input...
encrypted output...
writing...
success
kernelcache.release.s5l8900x (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/kernelcache.release.patch)...
encrypted input...
encrypted output...
writing...
success
Firmware/all_flash/all_flash.m68ap.production/LLB.m68ap.RELEASE.img3 (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/LLB.m68ap.RELEASE.patch)...
writing...
success
018-3885-4.dmg (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/018-3885-4.patch)...
encrypted input...
encrypted output...
writing...
success
018-3881-4.dmg (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/018-3881-4.patch)...
encrypted input...
encrypted output...
writing...
success
Firmware/dfu/iBEC.m68ap.RELEASE.dfu (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/iBEC.m68ap.RELEASE.patch)...
writing...
success
Firmware/dfu/iBSS.m68ap.RELEASE.dfu (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/iBSS.m68ap.RELEASE.patch)...
writing...
success
Firmware/dfu/WTF.m68ap.RELEASE.dfu (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/WTF.m68ap.RELEASE.patch)...
writing...
success
Firmware/dfu/WTF.s5l8900xall.RELEASE.dfu (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/WTF.s5l8900xall.RELEASE.patch)...
Exploiting 8900 vulnerability... ;)
writing...
success
Firmware/all_flash/all_flash.m68ap.production/iBoot.m68ap.RELEASE.img3 (C:\Program Files\winpwn-2.5\FirmwareBundles\\iPhone1,1_2.0.1_5B108.bundle/iBoot.m68ap.RELEASE.patch)...
encrypted input...
encrypted output...
writing...
success
Default root size is:500
Extracting Root Filesystem
Growing Root Filesystem
Replacing Kernel
Applying patch fstab.patch
retrieving...
patching...
writing...
success
Applying patch Services.plist.patch
retrieving...
patching...
writing...
success
Applying patch lockdownd.patch
retrieving...
patching...
writing...
success
Adding package BootNeuter.tar
Adding package Cydia.tar
Adding package Installer.tar
Adding package YoutubeActivation.tar
retrieving...
patching...
writing...
success
fixing up BootNeuter arguments...
Creating restore options (root size is:800)
start create restore options
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>CreateFilesystemPartitions</key>
<true/>
<key>SystemPartitionSize</key>
<integer>800</integer>
<key>UpdateBaseband</key>
<false/>
</dict>
</plist>
Rebuilding Root FileSystem (This will take a while)
Writing IPSW (This also will take a while)
IPSW builder finished
Starting Pwnage!
Getting iPhone/iPod status...
device connected in recovery mode
Status = 3
device disconnected in recovery mode
device connected in dfu mode
a takhle mi to uz stoji cca ctvrt hodiny.
Co s tim?
Naposledy upravil HFX9 dne sob zář 13, 2008 7:11 pm, celkově upraveno 1
masscre | sob zář 13, 2008 6:53 pm
Re: jsem zoufalej prosim radu s winpwn
A proc nahravas firmware 2.0.1? Nebo aspon podle toho logu se mi to tak zda. A taky si zvedni root memory size na 800Mb.
Uživatelský avatar Beavers | sob zář 13, 2008 6:56 pm
Ale nejprve zmenši ten screenshot, nabouráváš vzhled.
úte črc 01, 2008 3:17 pm
HFX9 | sob zář 13, 2008 7:12 pm
ja si root zvedl na 800
uz zkousim co se da i ruzne verze fw :cry:
Sortik | sob zář 13, 2008 8:32 pm
Mam stejny problem.. proste se to dal nehne :(
HFX9 | ned zář 14, 2008 12:56 am
Tak me uz vse funguje, mam ted odblokovany fw 2.0.1 s installerem a cydii
Pomohlo mi vse provest na jinem pocitaci s WinXP, kam jsem nahral jen itunes 7.7.11, winpwn 2.5 beta2 a pak postupoval nasledne:
Spustil winpwn a vytvoril si vlastni fw (tentokrat vse probehlo spravne az d konce)
pak jsem spustil itones a dal pomoci shift+restore obnovit svuj nove vytvorenej firmware
nakonec jsem nahral pres cydii cestinu a jede to vsecho perfektne
posledni co jsem udelal bylo nahrani openSSH abych mohl nahravat aplikace tretich stran :wink:
Takze kdokoliv budete mit jakykoliv dotaz klidne se ptejte, vim jaky to je byt beznadejny a vsem rad pomuzu. Moje icq je Vam k dispozici. (96130227)
