QUICKPWN probehl v poradku, pak prisel na radu proces s DISKAIDem a od ty doby se IP ani nerozsviti
postupoval sem podle navodu, ktery sem tu nasel:
12. On the right side, scroll down and click on the MobileInstallation.framework folder.
13. Select the MobileInstallation file, and click "Delete from Device".
13. Download the new MobileInstallation patch from http://www.sendspace.com/file/pcrxy6
14. In DiskAid, click "Copy File to Device", and select the MobileInstallation file you downloaded.
......smazal sem slozku MobileInstallation.framework + cache.....a bylo vymalovano, slozky sem si zalohoval...ale DISKAID mi iphone uz ani nedetekuje - i kdyz windows pripojeni i odpojeni IP reaguje tonem.
Poradil by mi nekdo co s tim...diky diky
pro upresneni jde o Iphone 3G porizeny ve Vodafonu - verze 2.1
