Model I
iPod car interface (model I)
The Xcarlink is a revolutionary product that allows you to connect your iPod or MP3 player directly to the CD changer port of your original car stereo for the best possible sound quality, it will even allow you to control your ipod through the controls on your stereo and steering wheel.
1) Perfect CD quality sound (NO FM MODULATION).
2) Control your iPod through stereo and steering wheel controls.
3) Control your Playlists through your car stereo Keeps your iPod Charged all the time.
4) 1/8-inch stereo jack for other auxiliary input.
5) Will not lock your ipod when connected Automatically Pauses your ipod when off or switched to another source.
6) Support iPod 3, iPod 4, Nano, Nano 3rd, Video, Mini, Touch, Classic, iPhone
Accessories:
1) iPod dock cable
2) VW tools for VW only
haasteren píše:Budes porad jak ko... preladovat je problem najit volne misto ktere udrzi stale porad mel jsem FM tuner od GRIFIN i cinske ( apropo z 10 ks shorelo po mesicibajecna koupe za 10 dolaru
Po utrapach a nasranich jsem radeji koupil toto
http://www.xcarlink.com/show_info.asp?product_ID=353
a mam klid a hlavne zadne sumeni ...
