iRedTouch (ovládač pre celý dom? Universal remote?)
Uživatelský avatar Apache23 | pon led 05, 2009 9:50 am
V app store sa objavila táto app:
iRedTouch tin:b Software
Category: Entertainment
Price: $29.99
Released: Aug 29, 2008
Seller: tin:b Software
Latest version: 1.1
Application description iRedTouch - the universal "Universal Remote"
Are you tired of having several remotes lying around in your living room? Do you want to use your iPhone or iPod touch instead? This and much more is possible with iRedTouch - in conjunction with an infrared (IR) transceiver module by IRTrans GmbH (http://www.irtrans.com).
Please visit iRedTouch website (link below) for details.
WITH AN ETHERNET MODULE:
- Infrared codes of all common devices (HiFi/TV/DVD/...) can be taught to iRedTouch
- using your fingers flip through the list of your remotes on the iPhone or iPod touch
- one finger tap on the photo of your remote - and the IRTrans transmits the respective IR signal
- hold down your finger - and the IR signals will be sent repeatedly, if appropriate
- no PC or Mac needs to be running for these operations!
WITH MORE ETHERNET MODULES:
- Control all IR-capable devices in your household, from anywhere in your WLAN
- Determine which remote will use which IRTrans module all over your network
HOW TO CREATE A REMOTE:
1. Make a photo of your remote, scan it, or even make a sketch of it
2. Copy the photo into iPhoto on the Mac, or into your Pictures folder on the PC
3. Use iTunes to transfer the photo into your mobile photo album
4. In iRedTouch choose the very photo as the touchable area of your new remote
5. Place the buttons on the screen, simply by tapping onto the photo
6. Teach the infrared signals to iRedTouch - a built-in assistant makes this easy
7. That's it!
IF YOU HAVE A MAC:
- Control "iRed2" on the Mac - a free license is included with certain IRTrans modules
- Use IRTrans USB modules connected to your Mac, just from iRedTouch via iRed2
- Control your Mac, change speaker volume, send it to sleep, ...
- Control iTunes, let iRed2 announce the current track, jump to the next album, set ratings, etc.
- All this and much more from iRedTouch on your iPhone or iPod touch
WITH YOUR MAC ON THE ROAD:
- Control applications on your MacBook (Pro), e.g. a PowerPoint or Keynote presentation - via WLAN from your iPhone
- Control QuickTime Player or VLC, or whatever. iRed2 is very flexible and adjustable to your needs
New in this version - Optional goto last remote after start
- Optional switch off screen auto-lock
- Better support for multiple modules
- "raw" learning of IR codes for very special remotes
- faster wake-up from sleep
- more automatic saving to prevent from data-loss
- German localization
- Several bugfixes
Languages English, German
Requirements Compatible with iPhone and iPod touch
Requires iPhone 2.1 Software Update
Ak som to správne pochopil tak je potreba tej škatulky čo majú na stránke a tá potom cez wifi bude vysielat infra a ovládať elektroniku? (Nebude treba nejaké infra aby presne na prístroj mierilo?)
Ak to niekto lepšie pochopil dajte vediet. Je to pomerne drahá app a myslím že niečo takéto sa od Iphonu slubovalo od začiatku a stále to nieje.
Ďakujem.
iPhone 4 32GB JB by GP
ned dub 27, 2008 1:58 am
pali777 | pon led 05, 2009 10:53 am
Re: iRedTouch (ovládač pre celý dom? Universal remote?)
JJ zhruba si to pochopil spravne...:) treba mat tu IR skatulku zavesenu na WIFI sieti...iPhone sa na nu napoji a daju sa tak ovladat jednotlive spotrebice:) Aj mne sa to zda byt dost podozrive, kedze IR potrebuje mat priamy dosah (dohlad:) na ovladane zariadenie, takze podla mna to funguje len v izbe v ktorej je ta krabicka polozena...takze o nicem:) A kedze iPhone nema IR tak ani nemusime dufat, ze as cez neho niekedy bude dat ovladat TV alebo ine zariadenia :)
harken | pon led 05, 2009 8:58 pm
Priamu viditeľnosť mať nemusí, napr. cez deku prejde, ale cez dlaň už nie.
Aj keď tá krabička je možno silnejšia než obyčajný ovládač...
Uživatelský avatar derik | sob led 10, 2009 10:37 pm
pri jednom mojom philips televizore sa dalo dialkove pouzit aj s inej izby, IR potrebovalo akurat volny priestor pre odraz signalu.
na tento ucel mi ale sluzi nokia so symbianom :)
iPhone
pon dub 14, 2008 4:38 pm
shnickell | čtv bře 19, 2009 2:57 pm
..takze bez wifi sa tv ovladat asi neda co? :)
Uživatelský avatar Apache23 | čtv bře 19, 2009 3:10 pm
Nie, som si takmer istý že wifi je nutnosťou. :wink:
sony123 | čtv bře 19, 2009 4:57 pm
Takže k tejto aplikácií treba ešte kúpiť nejakú vec čo vysiela IR?
úte srp 19, 2008 9:30 am
Uživatelský avatar Apache23 | sob bře 21, 2009 3:18 pm
Ano už to tak vyzerá. Bol tu topic s niečím čo dade na Kalifornskej univerzite vyrabali a to infra sa strkalo priamo do iPhonu do jacku na sluchatka. Vyzeralo to fajn nakolko by nič iné nebolo treba. No nejak to tam ale utíchlo. :wink:
