Agendus - správce úkolů (AppStore)
Uživatelský avatar Golf | čtv čer 25, 2009 6:20 am
Je tu další aplikace, notoricky známá na všech platformách, Agendus - správce úkolů. Asi jedna z nejlepších PIM aplikací vůbec.
http://www.iambic.com/agendus/iphone/
http://www.iampowered.com/archives/2009 ... stions.php
? Easy Navigation. Agendus for iPhone takes advantage of the unique page transitions, finger scrolling capabilities and ease of getting where you need to, for which the iPhone is known for.
? Customize to your liking. The preferences panel provides a variety of options allowing to fine-tune the app and its behaviour to the user's liking.
? Ready for iPhone OS 3.0. Agendus if fully compatible with iPhone OS 2.2 and above. Additionally, special care has been placed into making sure the app is compatible with the new OS 3.0.
? iPod Touch. The majority of the features in Agendus for iPhone can be used on the iPod Touch, including the Over-the-Air facilities (via WiFi), with the only limitations being placing phone calls and text messaging.
? Multi-Function Today View. Agendus for iPhone consolidates in one view your tasks, along with Real-time Weather Conditions (plus a 9-day forecast), an inspirational Quote of the Day and an informative Day in History snippet, each retrieved and updated with a simple touch over the related slot.
? Customize the Today View. You can rearrange the position of each Today View slot. Also, each slot is collapsible to show/hide the related information. It's also possible to define how many and what type of task to show.
? Contact List. Agendus reads from and writes to the built-in contact related storages of the iPhone, therefore any addition or modification made in Agendus is immediately reflected in the native Contacts App and vice versa.
? Expanded Contact View. In addition to the straightfoward Contact list, Agendus for iPhone features its unique "Expanded" mode, which shows the associated contact photo, as well as all of the phone numbers and emails directly on the list. Tapping on these numbers/emails will dial or start a new email message instantly.
? Tasks List. Agendus introduces a missing component on the iPhone: tasks (to-dos) and provides a number of facilities allowing complete task manipulation
? Advanced filtering and grouping options. The tasks in Agendus for iPhone can be filtered based on category, status, priority and due date. Therefore the Task View can provide an at-a-glance list of upcoming items based on how important they are to the user.
? Tasks and Contact Linking. In our busy todo-centric lives, most of our tasks are in some way related to another person. Agendus for iPhone allows to associate (link) a contact with each task, allowing to quickly reach the related contact via phone, text or email in order to follow up.
? Recurring Tasks. For tasks that are often repeated over and over, you can easily configure them to repeat by a number of different variables, so each time the ask is completed, it will automatically appear on the next date.
? Categorizing Tasks. In order to keep your task list organized, you can categorize each task, allowing for example to keep your business list of tasks separate from your Personal one.
? Color-coding Tasks. If you utilize task categorization, you can additionally associate a background color to the categories, which will then appear anywhere the task is shown, for an easy-to-read visual representation.
? Add Notes to your Tasks. You can add lengthy notes to each task in case you have additional information that cannot be summed up in a short description.
? Quickly see the status of your Tasks. The Task View exposes easily-recognizable "Status Indicators" for each task, so you know where you stand in getting things done.
? Task Detail Card. You can view each of your tasks in "Card Mode" which provides the important details about the tasks all on one easy-to-read screen.
iPhone X
MBA 2014 13" i5 8GB RAM
iPad Air 3 64GB LTE
Powerbeats Pro
Apple TV 2G + 4G
AW4 44
Mac mini 2018
sob bře 21, 2009 10:47 pm
patrix242 | čtv čer 25, 2009 7:50 am
Re: Agendus - správce úkolů (AppStore)
Agendus som používal na Palm-e asi 8 rokov. Ale s týmto sa to vôbec porovnávať nedá. Možno ako nejaká ranná beta, ale určite nie prezentované ako jedna z najlepších PIM aplikácii. Kalendárové pohľady mi strašne chýbajú, je tam veľa zbytočností - quote.... síce sa dajú vypnúť, ale...
Bol som dosť sklamaný.
úte čer 02, 2009 4:02 pm
