Fix Push na iPhone 2g
Uživatelský avatar caesar | sob črc 04, 2009 9:10 pm
Dev team uvolnil fix na nefunkcní notifikace na iPhonu prvni generace.
http://twitter.com/iphone_dev
pon úno 11, 2008 5:37 pm
Uživatelský avatar antton | sob črc 04, 2009 10:34 pm
Re: Fix Push na iPhone 2g
jeste by to mohl dat nekdo do cydie :)
úte dub 01, 2008 1:16 pm
bigmarian | ned črc 05, 2009 3:12 am
tak a uz mi nic nechybi na 2g
Uživatelský avatar cubas | ned črc 05, 2009 5:58 am
Ak mam ten balicek dostat do iphone?
iPhone | iPad | MacBook Pro | Mac mini | Apple TV
pát bře 28, 2008 8:22 pm
scorpi | ned črc 05, 2009 6:02 am
Já bych možná začal tím, že bych si přečetl README u toho souboru.
BTW Upozornění Dev-teamu: The installation is bit complicated and thus only advanced testers should attempt this for now.
stř bře 05, 2008 7:14 am
Uživatelský avatar cubas | ned črc 05, 2009 6:15 am
Obsah readme:
Push Solution Test Steps
A. Get Legit Keychain Data:
*You Must Perform These Steps On A Properly Activated Device (iphone or ipod touch) with at least one working push app*
1.Unzip the downloaded zip file and copy the binary 'nimble' using SSH into /private/var/Keychains and set permission to 0755
2. Make sure the file "keychain-2.db" is in /private/var/Keychains and run nimble. You will see 4 files being created:
- youtube-cert.bin
- youtube-key.bin
- push-cert.bin
- push-key.bin
3. Copy these 4 files into the corresponding folder on your hactivated device.
B. Testing Push:
*You Must Perform These Steps On Your Hacktivated Device*
1.Unzip the downloaded zip file and copy the following files using SSH into /private/var/Keychains and set permission to 0755:
- inject
- nimble
2. Store in somewhere else the current "keychain-2.db" and run inject. A new keychain-2.db will be created
3. Uninstall the push app (i.e. beejive or similar) you intend to test on from your hacktivated device and reboot
4. Test youtube, reinstall the above push app and test.
Uživatelský avatar lukas26 | ned črc 05, 2009 8:31 am
hmm, tak mně to nejede...divné...hledal jsem i jinde a akorát nikde není napsáno kam se mají ty 4 soubory překopírovat (prej mají zůstat tam kde se vytvoří), ale push mi nefungují...
edit: tak mi funguje tento návod s použitím jejich souborů z linku:
*download this file, and get the 4 files below.
http://www.mediafire.com/download.php?dydkmhgozj4
(thanks to member 3744111 for the link above)
3. Copy these 4 files which you got from the download below into the keychain folder on your hactivated device and leave it there.
? youtube-cert.bin
? youtube-key.bin
? push-cert.bin
? push-key.bin
B. Testing Push:
*SECOND PART*
1. Unzip the downloaded zip file and copy the following files using SSH into /private/var/Keychains and set permission to 0755 on both:
? inject
? nimble
2. make copy in somewhere else of the current "keychain-2.db" and run inject. A new keychain-2.db will be created (to run inject on winSCP, 1. click on "inject" file. 2. right click it and go to "custom command then press execute")
3. Uninstall the push app (i.e. Beejive or similar) you intend to test on from your hacktivated device and reboot
4. Test Youtube, reinstall the above push app and test.
stručný překlad:
- stáhněte si soubor z linku a extrahujte jej
- vlezte do iPhone přes WinSCP a nakopírujte 6 souborů (youtube-cert.bin, youtube-key.bin, push-cert.bin, push-key.bin, inject, nimble) do /private/var/Keychains
- nimble a inject nastavte práva 0755
- zazálohujte si někam soubor "keychain-2.db", protože se přepíše
- klikněte pravým na inject, Vlastní příkazy->Spustit
- odinstalujte push aplikaci, kterou chcete používat a restartujte iPhone
- vyzkoušejte youtube, znovu nainstalujte push aplikaci a jde se na to :wink: :
Naposledy upravil lukas26 dne ned črc 05, 2009 11:27 am, celkově upraveno 1
úte črc 01, 2008 4:26 pm
Uživatelský avatar caesar | ned črc 05, 2009 9:29 am
po provedeni toho prvbniho postupu ti stacilo nahrat jen ty 4 nove soubory aby ti to fungovalo, nebo to musim provest cele znova?
beky02 | ned črc 05, 2009 9:34 am
Podle návodu mi to nefunguje....
úte úno 19, 2008 3:02 pm
Uživatelský avatar lukas26 | ned črc 05, 2009 10:00 am
caesar: celé znova...ty co se vytvořily samy při prvním návodu jsem smazal a nakopíroval tady tyhle...
Uživatelský avatar caesar | ned črc 05, 2009 10:21 am
no problem je v tom, ze me se zadne samy nevytvori. Inject musim spoustet pres terminal v iPhonu, protoze v Cyberducku na Macu neni volba spustit. Nejaka akce probehne, ale youtube a push biny se nevytvori.
Uživatelský avatar lukas26 | ned črc 05, 2009 10:56 am
tak použij ten můj návod, kterým tam ty soubory nakopíruješ (btw inject je nemá vytvořit, ale ten druhý soubor je vytvářel)...no zkus to...
Naposledy upravil lukas26 dne ned črc 05, 2009 11:28 am, celkově upraveno 1
beky02 | ned črc 05, 2009 11:14 am
Potvrzuji funčnost....
Uživatelský avatar caesar | ned črc 05, 2009 11:54 am
No jak to tak pozoruju, tak ten problem bude nekde jinde. beeJive mi Push ukazuje, zatim co IM+ ne. BeeJive ovsem neukazuje cislo u ikony, jen hodi zpravu (nastevene v preferences to mam). Zmatek.
Tak už mi vše funguje. Postup zde http://steip.blogspot.com/
Uživatelský avatar marajs73 | ned črc 05, 2009 12:51 pm
A vy kterým to chodí, musí být zapnuto edge ? To jako jestli to chodí přes data nebo stačí WiFi ?
pon čer 09, 2008 9:03 am
Uživatelský avatar lukas26 | ned črc 05, 2009 1:09 pm
řekl bych, že přes data...i když jsem na wifi...vím, že to zní divně, ale měl jsem iPhone na stole u repráků, byl připojený na wifi a když jsem si na něj něco poslal a měla přijít Push, tak repráky začaly klasicky lupat, jako by měla dojít sms...takže lezly data...
edit: tak jsem to zkusil ještě tak, že jsem si EDGE vypl, byl jsem jenom na wifi, poslal si něco a zase repráky řvaly, i když EDGE je vypnuto...připadá mi to, že je to jako s MMS, které taky fungují, i když máte vyplé EDGE...
edit2: ještě jsem zkusil změnit APN a PUSH stále chodí, ale repráky před příchodem řvou...když jsem pak vypl wifi, tak jsem se na net přes Safari ale nedostal...zajímavé...
conectmetal | ned črc 05, 2009 1:57 pm
zdravím vás lidičky s tohoto vlákna ja viem že pre vás otázku ktorú položím bude blbá :? ale berte v úvahu že vy ste fajšmekry ohladom iPhonu ja sa len učím. Nepozerajte na deň mojej registrácie. Čo je to vlaste push ako to mne pomôže? Je to niečo také že môžem posielať MMS? Poprosím o serióznu odpoveď :wink:
Uživatelský avatar djlucas | ned črc 05, 2009 2:21 pm
Push jsou upozorneni z aplikaci... napriklad.. mas nejakou aplikaci na ICQ .. pustis ji pripojis se.. a jakmile ji zavres HOME tlacitkem tak se aktivuje push a jakmile ti nekdo napise ukaze se ti zprava na displayji jako kdyby ti prisla SMS ... jenze to nebude SMS ale zprava ze ti nekdo napsal na ICQ.. tohle nema s MMS nic spolecne...
Macbook pro
iPhone 5S 16GB White iOS 9
ned dub 27, 2008 7:19 pm
conectmetal | ned črc 05, 2009 3:20 pm
Supiš pochopené Ďakujem
Uživatelský avatar caesar | ned črc 05, 2009 7:53 pm
lukas26 píše:edit2: ještě jsem zkusil změnit APN a PUSH stále chodí, ale repráky před příchodem řvou...když jsem pak vypl wifi, tak jsem se na net přes Safari ale nedostal...zajímavé...
Tak to jsem zvedavej, jak mi tohle bude T-Mobile se Surf+Mail uctovat
Uživatelský avatar djlucas | ned črc 05, 2009 9:31 pm
caesar: tak to nejak prubni a pak dej vedet... to me taky zajima :lol:
Macbook pro
Uživatelský avatar cubas | ned črc 05, 2009 9:46 pm
Potvrzuji push na iPhone 2G, ja a dva kamaradi jsme tenhle navod s uspechem rozjeli.
makovice | ned črc 05, 2009 10:40 pm
Nechapu jak?? Kde jste vzali aktivovany push certifikaty na 2G v cechach?
Omlouvam se ... uz jsem to nasel ;)
sob pro 01, 2007 1:15 pm
Uživatelský avatar lukas26 | pon črc 06, 2009 12:53 am
caesar: to by mě taky zajímalo...mě to teda netíží, mám v iPhonu firemní SIMku a na ní mám aktivované data unlimited, ale pro ostatní to bude zřejmě fakt zajímavé...
Uživatelský avatar marajs73 | pon črc 06, 2009 7:39 am
http://cydia.iphoneil.net
V tomto repu už visí balíček fix push. Po instalaci máte vyzkoušet YouTube a když nefachá tak reinstal fix push.
edkis | pon črc 06, 2009 8:10 am
Vcera vecer som skusal na kamosoom 2g rucne nahodit ten pushfix a podaril osa mi to na 2x. Funguje aj youtube aj push.
úte pro 18, 2007 7:41 pm
Uživatelský avatar djlucas | pon črc 06, 2009 8:21 am
marajs73 píše:http://cydia.iphoneil.net
tak jsem to zkusil ale stejne mi to porad nefunguje... YouTube jede ale Push ne :lol:
Macbook pro
Uživatelský avatar jerrx | pon črc 06, 2009 5:46 pm
napodobne.. i po rucni instalaci i po instalaci z cydie mi push nejde :(
iPhone 5 | iOS 8
MacBook Pro | OS X 10.10
čtv bře 13, 2008 12:08 pm
bigmarian | pon črc 06, 2009 7:00 pm
push fix ze cydie mi funguje. supr
Uživatelský avatar maros2710 | úte črc 07, 2009 6:33 pm
no ja som si to nahral a mi to pri zapnutych push zozere baterku asi za pol dna:)
Original iPhone -> iPhone 3GS -> iPhone 5
pon črc 21, 2008 7:35 am
Uživatelský avatar marajs73 | úte črc 07, 2009 7:13 pm
Taky jsem to rozjel. Zkouším ještě v nastavení v mobilní data smazat z APN internet (mám firemní SIMku bez dat) a kupodivu PUSH chodí dál, ale data to nežere (nechápu jak to). Mám to u repráků ať vím kdy se telefon připojuje a zjistil jsem toto:
- Při vymazání APN a zapnutém PUSH je telefon nonstop jaksi "ve stavu připojení k vysílači" (repráky nonstop chrčí). Nevím jesli jste mně pochopili, ale asi je to ten žrout baterky :?: možná
- Při vyplnění APN (internet) přestanou repráky chrčet, a žere to asi 1kB/min mobilních dat.
Uživatelský avatar Antabelus | stř črc 08, 2009 5:24 pm
Doporučoval bych změnit název vlákna, takto je to dost zavádějící - tento fix je univerzální pro všechny hacktivované zařízení (ty zařízení, které nejsou aktivované oficiálně přes iTunes), což nemusí být jen 2G, ale i blokované 3G z dovozu či dokonce nové 3GS.
ned bře 09, 2008 11:22 am
edkis | stř črc 08, 2009 6:10 pm
Pushfix sice funguje ale uz ako niekto spomenul funguje tak na 50%. Na zaciatku chodia push spravy a potom sa akosi stracaju.
Uživatelský avatar Harrison | sob črc 11, 2009 1:47 pm
Tak by ma zaujimalo, ako to v skutocnosti je. Mam tu jeden 2G iPhone, prave som donho nahodil FW3.0. Nemam ziadny datovy program. Budu mi PUSH notifikacie chodit aj napriek tomu? Bez pripojenia k WiFi samozrejme.
    iPhone HW: iPhone2G(8GB), iPhone3G(8GB), iPhone5S (32GB), iPhone6 (64GB)
    Mac HW: MacBook Pro Retina (late 2013, 8GB, 256GB SSD)
    Ostatne: Apple Watch 1st gen., AppleTV 4th gen., Airport Extreme
úte čer 10, 2008 3:29 pm
Uživatelský avatar tvosi | sob črc 11, 2009 11:13 pm
mno bude, ale zaplatis za data :wink: protoze ikdyz nemas zadny datovy program tak mas aktivovana data, takze budes platit za kazdy preneseny kb
Obrázek iPhone 2G 8GB
pon lis 26, 2007 7:41 pm
Uživatelský avatar Harrison | ned črc 12, 2009 7:26 am
Jj, toho som sa obaval :? Diky za odpoved.
shauriq | pon črc 13, 2009 7:38 am
im+ a push notifikace.. na 2g... siilene mi to zere baterku.. za 2 hodiny zo 100% na 18%
stř črc 16, 2008 6:42 pm
Uživatelský avatar Harrison | pon črc 13, 2009 7:50 am
Dalsi z dovodov, preco to na 2G radsej nejdem aktivovat... :evil:
beky02 | pon črc 13, 2009 7:52 am
To není možné.... zapínám IM+ a na NotifyMe nastavuji upozornění na 11 hodinu. Stav baterky je 76 %. Po jedenácté napíšu kolik procent mám baterky...
Takže po 2 hodinách je stav baterky z 76 % na 62 %. Při nepoúžívání telefonu mi to baterku nebralo skoro vůbec. Měl jsem zapnuty PUSH u aplikací NotifyMe a IM+. Přes IM+ mi přišlo několik PUSH zpráv. Mezitím jsem udělal asi 10 hovorů. Nezdá se mi, že by to zase tak moc žralo baterku. O něco málo víc, než když PUSH nebylo aktivované... Nejvíc asi při telefonování a jiného používání.
Tomu, kdo je stále na cestách, tak bych doporučil PUSH vypnout nebo si pořídit do auta nabíječku. Ti co pracují v kanclu, tak si dají telefon do kolébky a nějaké vybíjení telefonu asi neřeší, alespoň já určitě ne. A přes noc mám telefon stejně na nabíječce.
Beky, aj pre Teba plati tlacitko EDIT :). Paly
Uživatelský avatar caesar | pon črc 13, 2009 6:47 pm
djlucas píše:caesar: tak to nejak prubni a pak dej vedet... to me taky zajima :lol:
Tak bohuzel se uctuje.
