Cena je 7,99 euro
Odkaz:
http://www.appigo.com/todo/
Screenshot:
Features in the Toodledo app that are not in Appigo Todo:
Length, Goal, Start Date.
Choose which fields to display, and the order of the fields
Views based on Due Date, Priorities, Tags, Status, and Recent. (I often use the Recent list to find recently added tasks.)
The same terminology as the Web app for Folders, Hotlist, and No Folder, which are called Lists, Focus, and Inbox in Todo.
Priorities are the same as Web app (Top, High, Medium, Low, Negative), compared to High, Med, Low in Todo.
Due Date has options: Due by, Due On, Due After, Optionally On
Can hide or show Negative Priority, Future Tasks, Deferred Tasks
Automatic sync is faster and less intrusive than Todo.
Easier way to sort tasks.
Automatic sync on edit. (Important feature if you're using Push notifications.)
Can set reminder for individual tasks.
Features in Appigo Todo that are not in the Toodledo app:
Ability to link a task to a Contact and automatically create a task with the Contact's name, and then call, email or SMS from the task, or go to the address in Google Maps, or go to a Website.
Subtasks are shown indented below the Parent task.
Can manually change the order of tasks in a list.
Can copy from Todo to Notebook and vice versa.
Can display Completed tasks as Strikeout (with many choices for displaying Strikeout).
Choices on how long to display Completed tasks, from one day to one year, or All.
Choice of which Lists (Folders) to display. (Useful if you use different Folders for Tasks and Notebook.)
A Checklist for creating simple lists of non-dated items.
