Popis
Aplikace na vzdálené ovládání přes Wifi multimediálního programu Media Player Classic (HomeCinema) bez nutnosti serveru na PC.Oficiální text autorů:[/u]
Popis:
- Easy and user-friendly interface.
- Supports remote control of any regular Audio Files, Video Files and DVD as well.
- Browse your PC hard drives for a Video or Audio Files directly from your iPhone!
- Take a snapshot of your favorite actor or scene and save it to the camera roll.
- See a basic media information on your device like Media name, actual position, total length and current player status.
- No installation of service application on your PC is needed!
- Connection is not stuck with WiFi! You can control MPC even using your 3G/EDGE/GPRS cellular network (Securing MPC on your router or firewall is recommended in this case).
- Media Player Classic runs on Microsoft Windows 95/98/NT/2000/XP/Vista/7 or a Mac machine with virtualized Windows system.
Instalace:
- Download free "Media Player Classic" or "Media Player Classic Homecinema" and run it.
- Go to the "View - Options" menu.
- In the "Player - Web interface" tab check "Listen on port" and select your desired port (Default 13579)
- Uncheck "Enable compression" and "Allow access from localhost only". Click "OK".
- Run MPCRemote on your device and connect to your PC hostname or IP address and Port number .
Podporované Media Players:
- Media Player Classic (v6.4.9.1 a novější)
- Media Player Classic Homecinema (v1.2.908.0 a novější)[/size]
Screeny:
Hlavní důležité údaje:
!! NEVYŽADUJE ŽÁDNÝ DALŠÍ SPUŠTĚNÝ SERVER NA PC !!
cena: 1,59 Euro
Recenze na iPhoneManii:
http://iphonemania.mobilmania.cz/MPCRemote-ovladejte-video-rovnou-z-gauce
AppShopper: http://appshopper.com/productivity/mpcremote
iTunes: iTunes.apple.com
Upraveny veškeré prohřešky proti pravidlům, týkající se fontů a jejich velikosti a barev. Doporučuji ti, abys, až ti vyprší trest, navštívil pravidla. Beavers.
