iBubbleLevel [AppStore] - Vodováha
Uživatelský avatar JackieTran | ned pro 27, 2009 8:59 pm
Rikal jsem si,ze tato mala aplikace se urcite hodi...
- Presne meri
2 zpusoby mereni :
- Horizontalne
- Vertikalne
Obrázek $0.99
Upraven název. Beavers.
Velikost: 1 MB
Hodnoceni: 4.43902
od 41 lidí
Dominic Rodemer
Level - Spirit level 4.2
iBubbleLevel expands your iPhone with a precise level.
Functions:
• calibrating function, making precise measurements possible
• horizontal measurement
• vertical measurement
• measurement on inclined surfaces of 45 degrees
Tips for a better accuracy:
The best measuring results can be achieved if the calibration is carried out using a real level!
Uživatelský avatar Tea Racer | ned pro 27, 2009 10:25 pm
Re: iBubbleLevel [AppStore]
Tak nevim jestli tohle kupovat když to je mnoho takovych aplikaci uplne zdrama :-)
pon bře 30, 2009 10:25 am
