MP3 2 Ringtone GOLD/AppStore/
Uživatelský avatar pistak | úte lis 02, 2010 10:41 am
Pridam sem aplikaciu na vytvorenie zvonenia v dlzke do 40sek. Mp3 si vyberete z pesniciek ulozenych v iPhone. Zaciatok zvonenia ci vyrez sa da nastavovat po stotinach, cize to je velke plus oproti konkurencii, tak isto sa da nastavit stisenie na konci ci na zaciatku zvonenia a plus nejake efekty. Samotne zvonenie sa potom objavi v iTunes kde si ho jednoducho ulozite do PC a potom presuniete do zvoneni iTunes.
Vyskusat mozete aj free verziu, ktora spravi zvonenie v dlzke max 20sek.
Obrázek Full Cena je 0,79?
Obrázek Free max 20sek zvonenie
Velikost: 28 MB
Hodnoceni: 1
od 1 lidí
Elma Digital ltd
MP3 2 Ringtone 3.6
MP3 2 Ringtone is a Sound convertor application. It uses MP3 songs in your iPod Library to make ringtones.
This application has good features beside converting,
* App is working on all iPhone models
* App supports fade effects for the beginning and end of the song.
* With fine tuning feature, you never miss a tone note.
* App supports file manager to manage app's shared folder.
NOTE: MP3 purchased from iTunes Store put DRM on all songs.So they contain copyright protection and cannot be used as input to create ringtones.
Velikost: 31 MB
Hodnoceni: 3.53333
od 15 lidí
Elma Digital ltd
MP3 2 Ringtone Lite 3.6
* Application supports not only MP3 format but also M4A, AIF, and WAV formats.
* You can create ringtones from your songs up to 20 seconds (40 secs in FULL version).
* You can change pitch and tempo of the song.(By this way a male voice can be changed into female voice :) )
* Application supports advanced file manager with album cover support.
pát pro 25, 2009 4:41 pm
john | úte lis 02, 2010 2:51 pm
Re: MP3 2 Ringtone GOLD/AppStore/
Řekni mi jedinej rozdíl, mezi tímhle a audikem, kromě toho, že za tohle dám ještě peníze?
Uživatelský avatar pistak | úte lis 02, 2010 5:16 pm
Neviem, to tvoje som zatial nepouzil lebo som o nom nevedel. Ale skusim ked budem doma a dam ti urcite vediet... :)
john | úte lis 02, 2010 5:23 pm
Jo, tak díky, jinak to audiko je internetová stránka, nemusíš kvůli tomu nic dávat do mobilu :)
Uživatelský avatar pistak | úte lis 02, 2010 5:36 pm
A kolko sekundove zvonenie z neho vycucnes? Ja som az vcera vdaka tejto aplikacii zistil, ze zvonenie moze mat az 40 sek. O tej stranke som nevedel, ale toti mi za 0.79? staci.
john | úte lis 02, 2010 9:22 pm
No zatim jen 30sec, protože víc snad ani nešlo, do 4.2 ne? Počítám stím, že do měsíce max to bude aktualizované. :wink:
Uživatelský avatar Metalgirl | úte lis 02, 2010 9:23 pm
Však do 40s vyzvánění můžu udělat i klasicky přes iTunes. Jedno mám 38s a iPhone to veme a neprotestuje. :) iOS 4.1
