Countdown Me [0,79€]
Uživatelský avatar rony | úte pro 20, 2011 7:54 pm
Aplikacia Countdown Me (slovensky vyvojar)
Aplikacia je notoricky "odpocet" k nejakemu vyznacnemu dnu, ktory si zvolite. Vie samozrejme naraz viacej takychto dni, viete si presne urcit den, vybrat termin z kalendara a pouziva PUSH. Vizualny dojem mam vynikajuci.
iTunes: http://itunes.apple.com/app/countdown-m ... 59849?mt=8
Velikost: 10 MB
Hodnoceni: 4.59259
od 27 lidí
TapMints
Countdown Me: Event Widgets 2.5.6
Create an event or select one from your calendar and track the remaining days on your home screen (or on your lockscreen on latest iOS) using widgets, or on the app icon’s badge. See the remaining days (minutes, seconds) without even opening the app.
Countdown Me lets you
- see a list of your countdowns without opening the app on your lockscreen (new on iOS 16), on your homescreen using widgets.
- see the remaining days to your most important event without opening the app on the app icon’s badge.
- create a new countdown quickly by selecting an existing event from your calendar or create a new event in the app
- create an alert for an upcoming event.
- see detailed countdowns: not only days, but also hours, minutes and seconds. You can enable this inside the app in Settings.
- share countdowns with your friends & family
Notes:
We use Apple PUSH Notification technology for updating the app icon’s badge number. In other words, for the feature to work, you should connect to the internet regularly. This is a limitation imposed by Apple — there is no other usable way of changing the badge number. The rest of the app’s functionality works also without internet connection.
Follow us on Twitter @tapmints
- see a list of your countdowns without opening the app on your lockscreen (new on latest iOS), on your homescreen (iOS 14 and later) or in the Today widget in case you use iOS 13 or older.
- share CountdownMeUITests with your friends & family
Notes:
Terms of Use: https://www.apple.com/legal/internet-services/itunes/dev/stdeula/
Uživatelský avatar Freaders | úte pro 20, 2011 8:40 pm
Re: Countdown Me [len 20.12.: FREE]
diky za info :)
iPhone SE 64GB Space Gray
Moto 360
Xiaomi Mi Band
iPhone 5C 32GB Blue
iPhone 4S 8.1.3
pát lis 06, 2009 4:31 pm
