PC iTunes ovladanie cez iphone (wifi,...)
niko9 | pát pro 30, 2011 1:51 am
Chcém sa sa spytat či existujé nejaka aplikacia do iphonu že ked mam na PC pusteny itunes a chcel b yoms ovladat puštanie hudby a dalšiu skladbu cez telefon cez wifi napriklad
je také niečo ? dakujem
Rap už nieje Ballin ale Swag
pon srp 15, 2011 10:22 pm
Uživatelský avatar Metalgirl | pát pro 30, 2011 2:03 am
Re: PC iTunes ovladanie cez iphone (wifi,...)
Si představ, přímo od applu, jmenuje se to remote, spolupracuje to přímo s iTunes. http://itunes.apple.com/cz/app/remote/id284417350?mt=8
Entertainment
27.02.2020 23:25
Velikost: 12 MB
Hodnoceni: 4.60289
od 39760 lidí
Apple
iTunes Remote 4.5.1
iTunes Remote is the best way to control Apple Music, iTunes, or the Apple TV app from anywhere in your home. Simply download the app to your iPhone or iPad, and connect directly to Apple Music, iTunes, or the Apple TV app on your Mac or PC.
With iTunes Remote you can:
• Access your Apple Music, Apple TV, or iTunes libraries
• Browse music by artist, albums, and songs
• Browse movies, TV shows, and podcasts
• Create and edit playlists
• See upcoming songs with Up Next
• Search your entire Apple Music, Apple TV, or iTunes libraries
• Explore shared Apple Music, Apple TV, or iTunes libraries
• Listen with AirPlay
• Send music to AirPlay speakers
• Group speakers together to play music in multiple rooms at the same time
• Set the volume on each speaker independently
Requirements:
• iPhone, iPad, or iPod touch with iOS 11.4 or later
• Wi-Fi connection to Apple TV, Apple Music, or iTunes on a Mac or PC
• macOS 10.15.2 or higher for Apple Music and the Apple TV app
• iTunes 12.8 or later is recommended for use with iTunes Remote
Nucleus | pát pro 30, 2011 12:25 pm
Nebo TouchMouse k ovládání PC takže i iTunes.
iPhone 2G 16GB - od 03.05.2008 do 23.07.2011
iPhone 4S 32GB - od 14.11.2011 do 17.1.2015
iPhone 6 64GB - od 17.1.2015 do 14.12.2016
iPhone 7 128GB - od 14.12.2016 do ?
ned čer 22, 2008 10:47 am
Uživatelský avatar Metalgirl | pát pro 30, 2011 2:11 pm
Remote je přímo na účely ovládání iTunes, nejjednodušší, co znám. Vidíš přímo svou library na displayi iPhonu či iPadu a jen mezitím klikáš a vybíráš interpreta, album, song, přeskakuješ skladby, ovládáš hlasitost atd. Nemusíš ani vidět na monitor, ten může být klidně vypnutý, celou library, co máš v iTunes vidíš přímo na displayi iDevices. Takže zbytečně žádné složitosti. Remote je přímo na tyto účely dělaný.
niko9 | stř led 04, 2012 1:08 pm
Diky kluci to remote je super :)
ale stale to je blbne.Ked odpojim od wifi a potom sa chcem znova pripojit tak iba piše žesa pripaja ku knižnici ale potom napiše že sa nemože pripojit
Musim znova vymazat pripojenie v telefone a nahodit kod do PC
Uživatelský avatar Metalgirl | stř led 04, 2012 1:28 pm
Zapni si homesharing na PC a v nastavení v Hudbě a taky nastav homesharing přímo v Remote.
