Aplikace pro Geocaching
D.U.K.E. | pon kvě 19, 2014 7:48 pm
Zdravim,
chtel jsem se zeptat, aktualne jako je nejaka slusna aplikace pro geocaching, jak nejaka free nebo nejaka placena varianta?
Dekuji
sob srp 28, 2010 1:55 pm
Uživatelský avatar Aparat | pon kvě 19, 2014 7:52 pm
Re: Aplikace pro Geocaching
stř srp 19, 2009 2:32 pm
mirmo80 | pon kvě 19, 2014 8:34 pm
Potvrdzujem, je skvela.
stř srp 08, 2012 1:00 pm
doctorf | pon kvě 19, 2014 8:37 pm
Používám ještě ´L4C Lite´ a spokojenost.
https://itunes.apple.com/cz/app/looking ... 70735?mt=8
Navigation
08.01.2021 17:56
Velikost: 61 MB
Hodnoceni: 2.57143
od 7 lidí
Michael Andreas May
Looking4Cache Lite 4.3.2
Looking4Cache is a app with a wide set of functions around the fascinating hobby geocaching. With direct access to over two million geocaches on Groundspeak´s Geocaching platform you can search for a box nearly everywhere.
In seconds you can store geocaches including all informations like the last logs, the waypoints and the images to your device over the direct API access (for this please read the annotation on the bottom). Or you can import a gpx file or a pocket query. All data will be stored on your device for offline usage.
Log your founds with trackables instantly or after your trip in the app. You can upload fieldnotes to the geocaching website too. And this not only for you but also for your complete team.
To save power the GPS accuracy will be switched based on the distance to your next target.
Here a list of the key functions:
Load Geocaches:
- through the Geocaching Live API
- load Pocket Queries or geocaching.com Lists
- import own GPX files
- GCVote integration
Manage lists:
- add Geocaches to lists
- use a lot of filers and sorts
- swipe a cache to build lists for your next trip
Maps:
- Online OpenStreetMap and Bing
- Online Apple Maps
- Send coordinates to other navigation apps
Log Geocaches:
- for multiple users
- with a log drafts, multiple for each log type possible
- log Travelbugs
- save logs locally
- Fieldnotes
Attention: To access the geocaches you need a user on Groundspeak´s Geocaching plattform (.com). According to your membership type the amount of data is restricted. Basic Members could load 3 full cache descriptions per day and up to 6000 basic descriptions. As a Basic Member the geocache search is restricted to traditional caches. To get full access and use all functions of this app you should have a premium account.
Attention: Continued use of GPS running in the background can dramatically decrease battery life.
ned zář 07, 2008 10:11 am
Smrdaky | ned kvě 25, 2014 9:31 am
Jak v teto navigaci se necham navigovat do cile pres Apple navigaci? To to vazne takovouto funkcionalitu po 5 letech nema? Nebo jak to delate?
Dalsi totalni nedomyslenost - nemoznost snadno vypnout Gps, nebot aplikace po celou dobu zapnuti vytezuje Gps na nejvyssi presnost (i kdyz to neni nutny) a to drancuje baterku.
stř dub 24, 2013 3:59 pm
doctorf | ned kvě 25, 2014 10:04 am
V 'L4C Lite' jde snížit přesnost GPS. Nastavení / GPS & Kompas
Smrdaky | ned kvě 25, 2014 10:56 pm
Ano, v jinych app. to jde nastavovat, v te ofiko app. ale stale ne
roco888 | ned čer 15, 2014 8:43 pm
Přidám se jen názorem - přešel jsem před nedávnem z Androidu na iOS a musím BOHUŽEL konstatovat, že nabídka "kačerských" aplikací pro iOS je ŽALOSTNÁ......
Naplno použitelná je vlastně jen první zmiňovaná, a to oficiální apka od GS - vše ostatní je jen slabý odvar.
Tak si musím povzdechnout - snad se někdy dočkám třeba C:GEO i na iOS :Search:
ned čer 15, 2014 7:55 pm
Smrdaky | úte srp 19, 2014 4:49 pm
Hlavne vsechny ostatni neoficialni appky maji pristup jen pres Geocaching API a musis byt premium, abys mohl pres to api nacist vic jak 3 kese za den :/
Takto si groundspeak zajistuje prisun penez (pres svou app nebo pres predplatne). Na androidu to asi aplikace delaji piratsky parsovanim html stranek, stejne jako Javovy Handy Geocaching...
Uživatelský avatar mikis.m.s | pát led 30, 2015 9:49 am
Zdarec,
Prosim muzete te mi nekdo vyzkouset zda fam funguje original geocaching aplikace? Uz dva dny mi nejdou nacist kese. Otevre se seznam kesi, ale nelze je otevrit ani nic jineho. Deje se mi to dva dny a zkousel jsem preinstalovat apku i hard reset atd. Mozna je to tim ze mam ios 8.2 beta? Diky
Naposledy upravil mikis.m.s dne pát led 30, 2015 12:47 pm, celkově upraveno 1
iPhone 7 128GB Black, iOS 10.4 nonJB O2
iPad Pro 10,5 64GB LTE Silver iOS 11.3.1 nonJB T-Mobile 10GB
Apple TV 4K 64GB, tvOS 11 with Kodi
PC 8700K 5,2GHz, SSD 960 Pro 1TB + HDD 2TB, DDR4 32GB, GTX 1080Ti EVGA Hybrid
ned úno 08, 2009 6:29 pm
mirmo80 | pát led 30, 2015 10:39 am
U mňa OK. Nájde blízke skrýše a viem ich rozkliknúť a ďalej s nimi robiť.
Uživatelský avatar mikis.m.s | pát led 30, 2015 12:47 pm
Tak je to jasné mám to potvrzené už od dvou lidí. Je to betou iOS...
Sry za OT.
jeenik | čtv črc 14, 2016 4:52 am
Koukám jako blázen, už není k dispozici má zaplacená originalní appka pro geocaching, je jen verze zdarma, zato však ořezaná a skoro nefunkční bez předplatného?!!!
ned úno 08, 2009 5:20 am
Onygzzer | čtv črc 14, 2016 6:12 am
No tak to mě teda poser! Já to ani nezaregistroval, protože už dva roky jsme PM, takže funkčně to mám pořád stejný, nicméně proč jsem vyhodil ty nemalý prachy za tu full appku tenkrát??? :(
sob led 10, 2009 3:48 pm
mirmo80 | čtv črc 14, 2016 6:34 am
Tak snad to bude nieco docasne. Este v nedelu som instaloval synovi ako mnou zakupenu a vsetko ok.
jeenik | čtv črc 14, 2016 6:49 am
Obávám se, že ne... Kdyby to aspoň nestálo tolik. Pro občasného uživatele špatná zpráva.
Uživatelský avatar korwin | čtv črc 14, 2016 11:47 pm
jeenik píše:Koukám jako blázen, už není k dispozici má zaplacená originalní appka pro geocaching, je jen verze zdarma, zato však ořezaná a skoro nefunkční bez předplatného?!!!
Pokud mas nainstalovano v telefonu, tak si ji zazalohuj v iTunes a můžeš instalovat i bez AppStore.
sob dub 03, 2010 6:04 am
Onygzzer | pát črc 15, 2016 2:20 am
No to nevím, protože já mám v telefonu nainstalováno ještě z doby kdy byla free i placená verze a teď mám v telefonu tu jednotnou GC Classic...asi se to v tichosti sjednotilo v rámci updatů.
jeenik | pát črc 15, 2016 4:59 am
Tomu nerozumím, mám samozřejmě obě, ale ta první již v appstore není, jasně, je možné ji zálohovat, ale podpora končí, možná až bude iOS 11, tak už ani nebude fungovat...
Asi přejdu na pokemony [emoji57][emoji854][emoji35]
Onygzzer | pát črc 15, 2016 7:22 am
No tak to je teda fakt super totok...tady je k tomu ofiko vyjádření jak se věci mají:
https://support.groundspeak.com/index.p ... age&id=692
mirmo80 | pát črc 15, 2016 9:48 am
Ale pre mňa zaujímavé je, že v rámci family sharing si to moji stále vedia stiahnuť. Teraz som to nainštaloval manželke, tak odkiaľ tie appky ťahá, keď už nie sú v App Store? Z iCloud zálohy?
Uživatelský avatar DD_ | pát črc 15, 2016 11:57 am
Oni jsou v Appstore, ale stahnout si je maji sanci pouze lide, kteri si je pred tim zakoupili. Nikdo jinej tam tu appku uz nenajde. Proste se zobrazuje pouze v tvych nakupech a nikoli verejne ve vyhledavani.
Macbook Pro 13" 2017
iMac 21.5" late 2012
Apple Watch 3 Sport 42mm
čtv srp 12, 2010 12:48 pm
