No strašnej expert.. kterej zapomene heslo...
no víš, mám tam takový svoje poznatky a různý stránky a jména aut a ruznejch zajimavejch věcí, který už třeba nikdy nezjistím...
ale nevím costim...
tak sem stahnul to restore a hodilo to error 3001 s vysvětlením takto.. :
2009-12-27 19:31:09.187 iTunes.exe[912:1b0]: restore library built Aug 24 2009 11:22:55
2009-12-27 19:31:09.281 iTunes.exe[912:1b0]: iTunes: iTunes 9.0.2.25
2009-12-27 19:31:09.296 iTunes.exe[912:1b0]: iTunes: Software payload version: Unspecified
2009-12-27 19:31:10.609 iTunes.exe[912:c80]: iTunes: Specifying UOI boot image
2009-12-27 19:31:12.406 iTunes.exe[912:c80]: phoning home to gs.apple.com:80
2009-12-27 19:31:12.421 iTunes.exe[912:c80]: tss_add_entry: ApECID
2009-12-27 19:31:12.421 iTunes.exe[912:c80]: tss_add_entry: ApChipID
2009-12-27 19:31:12.421 iTunes.exe[912:c80]: tss_add_entry: ApBoardID
2009-12-27 19:31:12.421 iTunes.exe[912:c80]: tss_add_entry: ApProductionMode
2009-12-27 19:31:12.437 iTunes.exe[912:c80]: tss_add_entry: ApSecurityDomain
2009-12-27 19:31:12.437 iTunes.exe[912:c80]: tss_add_entry: UniqueBuildID
2009-12-27 19:31:12.437 iTunes.exe[912:c80]: tss_add_entry: @Locality
2009-12-27 19:31:12.437 iTunes.exe[912:c80]: tss_add_entry: RestoreLogo
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: RestoreDeviceTree
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: RestoreKernelCache
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: RestoreRamDisk
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: iBEC
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: iBSS
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: KernelCache
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: BatteryLow1
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: BatteryLow0
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: LLB
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: iBoot
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: DeviceTree
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: BatteryCharging1
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: AppleLogo
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: BatteryPlugin
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: BatteryFull
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: BatteryCharging0
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: RecoveryMode
2009-12-27 19:31:12.453 iTunes.exe[912:c80]: tss_add_entry: NeedService
2009-12-27 19:31:19.843 iTunes.exe[912:c80]: received tss response
2009-12-27 19:31:20.015 iTunes.exe[912:c80]: [tss] could not open file for reading
2009-12-27 19:31:20.015 iTunes.exe[912:c80]: [tss] tss_read_file failed=10001
2009-12-27 19:31:20.031 iTunes.exe[912:c80]: failed to merge img3 (File not found)
2009-12-27 19:31:20.031 iTunes.exe[912:c80]: failed to personalize BatteryLow1
2009-12-27 19:31:30.843 iTunes.exe[912:c80]: _AMRAuthInstallCopyPreflightOptions: failed to personalize bundle (3001)
2009-12-27 19:31:52.640 iTunes.exe[912:1b0]: iTunes: Restore error 3001
máte nějaký nápad? nechapu, proč se to stahuje pokaždy znova, to neni nikde v PC? proč by se to mohlo přád stahovat znova? mezitim se iP vypne a zapne se do normálního zablokovanýho módu...
