bluetooth
pharelkoo | čtv dub 15, 2010 2:37 pm
bluetooth
da sa posielat bluetoothom subor medzi ipod touch a mobilom??
pon bře 29, 2010 4:17 pm
dwik2 | čtv dub 15, 2010 2:40 pm
Re: bluetooth
bez jailbreaku ne
pharelkoo | čtv dub 15, 2010 2:42 pm
Re: bluetooth
a neda sa stiahnut nejaky program na to?
Uživatelský avatar H0NZ1K | čtv dub 15, 2010 2:45 pm
Re: bluetooth
bez jailbreaku, ne ;-)
na AppStore je akorat Bluetooth Photo Share
Velikost: 5 MB
Hodnoceni: 2.21739
od 23 lidí
nathanpeterson.com
Bluetooth Photo Share 1.5
Previously the #1 App worldwide in all categories according to applyzer.com! Thank you for your support. We have more updates coming soon! Also, check out Bluetooth Photo Share Pro!
Transfer photos and/or contacts between two iPhones and/or iPod Touches over bluetooth. Requires iPhone 3G or later or 2nd generation iPod Touch or later (Bluetooth data transfer cannot be supported on the original iPhone or original iPod Touch due to hardware limitations). Does not require any 3G or WiFi connection.
This is the best bluetooth photo sharing app out there, and it's free!!
Here are some features that make this app stand out:
- Unlike some other photo sharing apps, Bluetooth Photo Share does not scale down or do any lossy compression of your photos before transferring. In other words, the receiver gets the exact image that was in the sender's photo library.
- Allows you to transfer contacts from your address book.
- The receiver transfer screen includes a thumbnail preview of the photo AS IT IS BEING TRANSFERRED and a cancel button so that you can cancel the transfer if you decide you do not want it.
- Shows a scrollable list of thumbnails and file sizes for all of the images that you've received.
- Allows you to view your photo albums that your photos were saved in.
- inApp Upgrade available Select Multiple Photos and remove Ads.
We are also working on some great new features that we hope you'll really like. We have a website(in English):http://iphonemart.net. Also check us out on twitter at http://www.twitter.com/iphonemart
Most of the time, the app works great. However, when people experience problems, 99% of the time it is related to connecting with bluetooth, which would be the same for any bluetooth App. If you have any trouble connecting, please check our support webpage for troubleshooting information.
Note that if you are trying to transfer photos from your old phone or to/from your computer, there is no way to do that on the iPhone with bluetooth.
Naposledy upravil H0NZ1K dne čtv dub 15, 2010 2:47 pm, celkově upraveno 1
čtv lis 06, 2008 7:45 pm
pharelkoo | čtv dub 15, 2010 2:46 pm
Re: bluetooth
ok diki moc a ked to uz tu pisem jake to ma vyhodi ked si ipod jailbreaknem?a nevyhody?
Uživatelský avatar H0NZ1K | čtv dub 15, 2010 2:48 pm
Re: bluetooth
vsechno potrebne mas napsane na foru ;-)... zkus trosicku Hledat
lck ls8
