Novy iTunes 10.0.1
Uživatelský avatar JackieTran | sob zář 25, 2010 10:02 am
Novy iTunes 10.0.1
Novy iTunes 10.0.1 je jiz k dispozici .
V novem updatu iTunes prinasi nove vylepseni Pingu
Kód: Vybrat vše
iTunes 10.0.1 makes it easier to share your favorite music with your friends on Ping. You can now Like or Post about music right from your iTunes library. You can also easily see the recent activity of a selected artist in your library, or of all artists and friends you follow on Ping using the new Ping Sidebar.
This release also provides a number of important bug fixes, including:
? Addresses an issue where the picture quality of a video changes depending on whether the on-screen controls are visible.
? Resolves an issue where iTunes may unexpectedly quit while interacting with album artwork viewed in a separate window.
? Fixes a problem that affects the performance of some third-party visualizers.
? Addresses an issue where the iTunes library and playlists appear empty.
? Resolves an issue that created an incompatibility with some third-party shared libraries.
iTunes 10 comes with many new features and improvements, including:
? Introducing Ping. Use Ping to follow your favorite artists and friends or connect with the world?s most passionate music fans. Discover the music everyone is talking about, listening to, and downloading.
? Rent HD TV episodes for just 99? each. Watch them on your Mac or PC, on-the-go with iPhone or iPod touch, or in your living room with the all new Apple TV.
? Play your favorites on the all new iPod touch, iPod nano, iPod shuffle, and Apple TV.
? Play music wirelessly with AirPlay on AirPlay-enabled speakers, home theater receivers, and iPod accessories.
? Explore many look-and-feel improvements throughout iTunes.
? Enjoy performance improvements which make iTunes faster and more responsive.
? Additional voice support with VoiceOver Kit for iPod.
McDog | sob zář 25, 2010 10:03 am
Re: Novy iTunes 10.0.1
Zvlastne.Ja som pred hodinou daval Check updates....a nic
Uživatelský avatar JackieTran | sob zář 25, 2010 10:04 am
Tak zkus znova.
McDog | sob zář 25, 2010 10:05 am
Jj len co nahodim vsetko po restore...
Edit:inak troska mi to pripomina teraz moj oblubeny prehliadac Flock:)
Masorad | úte zář 28, 2010 9:39 am
Coze, mne vyhodilo update az dnes. Teda ak som ho (alebo moja slecna) pred par dnami nechtiac neignoroval.
Uživatelský avatar Nolf | úte zář 28, 2010 9:47 am
No pokud se mi to neupdatuje samo, nechám si současnou verzi, kde mám češtinu.
No One Lives Forever
pát zář 24, 2010 3:34 pm
